Question about Scosche Industries Scosche High Performance Amplifier Car Audio Amplifier
Fuse problems My amp stoped working so i checked the fuses that are on the amp and they where both blowin, so i tried to replace them but they where instantly blowin. I then looked over the power and the ground wire they appeared to be cut free and well conected. I than just conected the power and ground with new fuses and they where blowin. I am out of ideas.
  • Shawn Mcgrath
    Shawn Mcgrath Jul 14, 2007
    Andyrst i am not very fimiular with car audio, can you describe what and where my output leads may be?
    New Friend:
  • 83 Answers
Output leads shorted by chance?
Posted on Jul 12, 2007
SOURCE:
Hello, my Mitsubishi m-vr400 was left on over night and now only 1 speaker works and I can barely hear it at half volume, did I fry the amp? Thanks
I am a retired Certified electronic technician,Of 35 years.What you can try end sometimes it will work, On the top or the side of the cover,Hit it fairly hard with your hand. If it cuts in end fades out hit it again. I have done this with amps or recievers,End probably got over 60% of them working again buy doing that. If that does not work then take the cover off off, To look if there is any fuses inside the unit, That might be blowin.If there are no fuses blowin, Then it did blow a power Transister.
Oct 27, 2012 | Audio Players & Recorders
TURN SIGNALS & FLASHERS DON'T WORK
First check for a blowin fuse for them. If the fuse is good ,You need to change the signal light flasher.
Oct 25, 2012 | 1995 Plymouth Neon
When I jumped my batterie i accidently reversed the negative and posotive after, the radio stopped working I checked fuse, fuse was ok what do i check now
There is usually more than one fuse for the radio.
in the instrument panel fuse block there will be an AUDIO fuse and an AV fuse. If the radio has an amp there will be an AMP fuse in the under hood fuse block.
If all three of those are good let me know and I'll try to help you further.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Apr 20, 2011 | 2005 Kia Sportage
1984 stove, fuses located on the top of stove/ 30amp keeps blowin
It sounds like the element has a short in it. unplug the range, and take the element out and inspect if for burn marks. check the wires going to the element to make sure they have not shorted.
Jul 01, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
How come it blows 30 amp atc fuse instantly even with the system off
check connections are hooked up properly if it blowin the fuse with it off sounds like something is really wrong on inside get it checked out
Jun 04, 2010 | Kicker KX200.2 Car Audio Amplifier
99 jetta driver side headlamp won't work.fuse keeps blowin.
Unplug the bulb and try the fuse again. If the fuse doesn't blow, replace the bulb.
Mar 12, 2009 | 1999 Volkswagen Jetta
Left directional and break lights on my 2001 jeep grand cherokee won't work. I've already replaced bulbs several times and the entire assembly
check the fuse for it, it maybe because its to big an keeps blowin them. an when you replace one side go ahead an replace the other side as well this should keep from blowin them.
Jan 02, 2009 | 2001 Jeep Grand Cherokee
Blown fuses
there is a possibility that the current load is excessive nor there is a short circuit from elsewhere, do not try to install again a new fuse unless you are certain there is no shortages of any wire from inside the amp and throughout the system by physical inspection
also install the right value for your fuse meaning the right amp and voltage, high temp is an indicator of shortages and defective power transistor
Oct 06, 2008 | Pioneer GM-X862 Car Audio Amplifier
Subwoofer stop working
push down on the speaker, does it make a ruff nosie? if so the speakers voice coil is blowin. did ya check the amp to the subs?
could be a lot of things . check the amp make sure it has power,
do u have an in line fuse? if so check that ,to make sure it aint blowin
May 26, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Scosche Industries Scosche High Performance Amplifier Car Audio Amplifier Logo
105 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
Vincent G
Vincent G
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
