Question about Frigidaire Dryers
REMOVING DRUM FROM LE02152ESO - Frigidaire Dryers
I have a kyocera FS-1370DN with error code 7990:0116216. What is the problem?
the drum unit is full of waste toner empty it by removing drum unit and removing small covers on both sides dump all toner out of unit then reinstall the covers then the drum unit
Sep 15, 2017 | Kyocera Office Equipment & Supplies
Tip
Drum needs to be replaced message,Remove waste toner,Waste toner full
Save money by removing your drum units waste toner yourself.By removing waste toner the drum life will be increased.Remove the waste toner every 3 to 5 thousand prints.
The main cause of drum failure in this model is caused by waste toner build up at the back of the drum,this cause the drum cleaning blade to put more pressure on the drum and.
Slide the platte-ned cover Assembly to the left open the left cover,remove the drum and developing Assembly like you do when you have to remove a paper jam.The drum and developer assy is attached by 2 blue clips,unlock the clips and separate the def and drum.On top of the drum unit the is a plastic plug that you can remove and trough out the toner in a dustbin with plastic bag coverd.Do not use this toner again in the machine.
Reinstall the plug and connect the drum and developer unit with the two clips.Reinstall the unit.
By removing the waste toner regally you will save on service cost as well.
on Dec 05, 2009 | Canon ImageRUNNER 1670F Copier
I can't find where to hoop up the dryer plug receptacle on my Frigidare dryer model# LE02152ESO
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2011 | Frigidaire Dryers
LE02152ESO runs but won't heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 23, 2011 | Frigidaire Dryers
How do you reset dryer with model # LE02152ESO
Your fuse on these dryers is on the back side of the dryer. themobilian_1209.jpg
I have a page with videos and a service manual HERE
Looked up your model number. Didn't work
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 31, 2011 | Frigidaire Dryers
Sharp copier, not producing clean copies
Could be the fusing unit (part that gets hot) but most likely cause based on your description is the drum unit. Easy to check by simply removing your toner cartridge, then removing the drum cartridge which sits right next to the toner cartridge. After removing the drum cartridge, turn it over and look at the colored cylinder. This is the drum. It should be clean. If your problem is in the drum unit you will see the same 2 "bands" of toner are something on the drum surface. If this is the case, it means the drum cleaning blade is going bad. Just order in a new drum unit and this will fix the copy quality problem.
Good Luck and Thank You for using Fixya.
May 09, 2010 | Office Equipment & Supplies
Drum is making a knocking noise
it could be the rear drum bearing going out or the rear drum rollers going bad or the roller wheels beginning to flatspot or the front rollers in the same shape,you would need to remove the front cover on the unit by removing the lower kick panel screws,then remove the top cover and removing the drum belt,then remove the drum from the machine to examine all the above issues noted
Apr 27, 2010 | Kenmore 63942 Dryer
Canon IR 2830 how do I install drum assy? How do I put in a drum unit for the IR 2830.
A.Removing thr drum unit.
Opem the front cover,shift down the developing assembly lockimg lever to unlock the developing assy.Slide out the left cover,holding the grips,pull out the drum unit.When removing the drum unit be sure to hold the two grips and take care not to scratch or soil it.
B.Cleaning the photosensitive drum.
If the surface of OPC drum is soiled wipe it with a flannel cloth coated with toner.Do not use paper,lintfree or otherwise.
Nov 22, 2009 | Office Equipment & Supplies
CHIRPING CLOTHES DRYER
The problem sounds like your drum rollers, you can try to lube them by pulling the front of the dryer off and removing the drum. Or you can replace them by removing the front of the dryer and removing the drum.
Sep 25, 2009 | Maytag Dryers
Stainless steel drum loose
A loose inner drum usually indicates a failed rear tub bearing. The only solution is to replace the rear half of the tub. (which contains the bearing).... You can check if the pulley nut has come loose by removing the rear panel. There is a large nut that retains the belt pulley to the shaft of the basket.
Jun 04, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
16 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
