Question about Diesel Watch DZ1123
Diseal dz1123 has stopped working
My son took it off for two weeks and now it wont work
Stop beeping hour?
According to the directions: Press B - bottom left button,to go into Alarm Mode. Press D - upper right button - to activate the alarm and press again to activate the Chime, which shows on bottom left as a bell. To activate these press D. To DEACTIVATE them press D again. Press B 3 times to return to Time Telling Mode. It took a few tries, but D and B are the keys to stopping that annoying chime!
Oct 18, 2013 | Armitron All Sport Digital watch
Nike Triax Fury works after replacing battery, but buttons wont work or change anything!
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Good luck.aa07e646-2c11-45e3-b8fa-b40ec2fd82c2.jpg
Nov 29, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
Backlight for my breitling aerospace has stopped working, otherwise watch is working perfectly.
I am in South Korea. My back light has stopped working and I took it to the dealer/service office in Seoul and asked them if they could repair it. Then took it apart and said everything works find, but for the back light, I should just order a whole new analog works...is he just trying to make some money off me?
Oct 15, 2012 | Breitling Aerospace 455 Wrist Watch
DZ1123 broken glass
Many areas have places you can take the watch and have the glass replaced if you google search watch fixers in your area and google map them you should be able to find one close by.
Nov 29, 2011 | Diesel Watch DZ1123 Watch for Men
10 year old Seiko Kinetic (model5M62-0B00) blue face. Last week stopped and after some shaking started again but seconds moved in 2 sec intervals for a few hours. Went OK for a week and again last night...
After 10 years it will be likely that the Kinetic capacitor will need upgrading. Your watch is designed to tick in two second intervals to tell you the power is very low. The power button will work again when it has some power to show. Yorkshire Watches www,yorkshirewatches.co.uk can do the upgrade for you if your in the UK. Give them a ring.
May 23, 2011 | Seiko Kinetic watch
Watch has new battery but suddenly stopped.
Might need cleaning, oiling or other servicing ...
What do you think?
Thanks for your interest in FixYa.com
Feb 19, 2010 | Tag Heuer F1 Indy 500 CAC111B.BA0850
The battery was changed two weeks ago. A week
Greg it sounds like you should take your watch to a propper watchmaker. (qualified) Most jewellers are not well educated in regard to watches and their servicing.
Jul 16, 2009 | Watches
Keeping 2008 breitling cockpit watch running
You have to wind the watch till it is fully wound (significant resistance should be felt).
It doesn't matter how many times you wind it (1 or even 40) - what matters is the strength of the spring.
Do as follows:
At any time in the morning wind the watch up till you feel there is no more winding left (should be quite tough). Memorize the time you did it.
Leave the watch (or wear it) till it stops completely.
Count the hours your watch did work (from the time you wound it).
Now you know exact power reserve for your watch.
It is advised to wind the watch 2-3 hours before the power reserve is gone.
Rate me.
, please.
Apr 08, 2009 | Breitling Navitimer A2332212 G5 431A watch
My Rado Voyager automatic watch has stopped running. What could be wrong with it and how do I fix it? Thanks.
it is because eaitther u have not worn it for a long time 84 hours it could have stopped or (i know it is water and dust proff but that is when it is new and it will be only dust proff )u may a took it in the shower or dropped it in the water or u took ir of and kept it in the bathroom the watervapour will harm the watch there is no onther way it can stop if u dropped it it wont breck easy
Aug 13, 2008 | Rado Watches
Diesel Watch DZ1123 Logo
24 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Diesel Watch Expert? Answer questions, earn points and help others
