Question about Toshiba Computers & Internet
After a few minutes plugged in the power/battery lights flash
I am unable to power up my laptop because power does not seem to be getting through properly
  • 1 more comment
  • Anonymous Feb 04, 2009
    i have that problem too
  • bobatluri Mar 14, 2009
    power is not just on
  • Anonymous May 20, 2009
    same prob, tried taking out battery, harddrive and memory and still same thing
  • Toshiba Master
  • 32,281 Answers
I would check the power adapter.
Test the power plug on the adapter with a multi-meter, the voltage should be slightly higher that the voltage that is printed on the label on the bottom of the power adapter.
If the voltage is zero or very low the the adapter is faulty and needs to be replaced.
If the power adapter is OK then the fault could be a faulty power socket on the laptop's motherboard. Plug the adapter's power plug into the laptop's power socket and wriggle the power plug, if the power/charge LED flashes then the socket may have a dry solder joint or the socket maybe faulty and needs to be replaced.
This is a common problem with laptops and to fix and/or replace the socket requires the laptop to be completely dismantled. Get a quote from a repair as it is not cheap.
Posted on Jul 20, 2009
My dell inspiron plugged in not charging
buy a replacement charger
if this does not work
i suspect the socket is perhaps damaged
sometimes its the laptops power management
so take the battery off
open the screen
press the power on
wait a few seconds
plug the battery back and the power
and see if the light flashes for charge again
i do suspect the charger or the laptops power socket...
Apr 19, 2015 | Dell Computers & Internet
When i charge my acer aspire the power button flashes
The DC jack in the laptop is showing early signs of intermittent issues, the jack is solded to the motherboard which sometimes breaks free over time, this is something that will eventually need to be addressed.
Mar 25, 2012 | Acer Aspire 5336-2283 Notebook
Won't turn on
Try to do the following . . . removed the battery then plug the power adapter to the laptop. If you are not getting a green light on this that means there's something wrong with your power adapter.
Try also plugging to a different power socket. We'll just make sure that the power source is not the issue.
If still you are not having success on this it is advisable to visit the nearest acer shop and let them check the laptop. The issue might be internal.
Hope this helps . . .
Apr 03, 2010 | Acer TravelMate 5520 Notebook
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Amber light constantly flashes when trying to charge
Hi there.
The battery could be faulty, power off the laptop, take out the AC power and the battery wait 2 minutes and put the battery back in, turn the laptop an and look at the indicator LED to see if its changed, if it has plug in AC power and see if its the same.
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | Packard Bell Easy One II 3136 Notebook
Not able to hold a charge and orange light flashes
as an EX dell tech your battery is dying
just get another battery
Apr 10, 2009 | Dell Latitude 120L Notebook
I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries,...
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Jan 04, 2009 | Computers & Internet
Flashing amber battery light
Sure, this just mean your are in charging mode, but your battery is at full charge. Should your battery need charging and in charging mode the lights would be green most likely.
Regards,
Worldvet
Please don't forget to rate our solutions as fixed if we answered your questions or fixed your problem.
Jul 13, 2008 | Dell Inspiron 2200 Notebook
Flashing icon at the top right of my Dell Inspiron 6400
seems your battery cell is the one having that issue. try replacing the battery or plug the laptop and let it recharge the battery to full.,
Oct 28, 2007 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
309 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
