Question about KitchenAid Refrigerators
My kitchen aid model kscs251nss00 ice maker doesn't work but it does dispense drinking water could the problem be the water control valve?
the dr
  • 447 Answers
SOURCE: Ice Maker problem 106-626636
Pull the front cover off the i/maker. There are holes on the module(the piece with the large gear) They are labeled T an H at around 5 oclock L and V around 6-9 oclock use a piece of wire to jumper l and v first it should start to fill if it doesnt the fill tube may be iced up, if it does fill then jumper t and h for about 6-10 secs or until it will advance by itself. Also whirlpool had a batch of faulty modules the large gears were breaking if it wont advance or if the plastic gear falls off easily then this is the problem. Dont forget to rate my solution!! Thanks!!!
Posted on Oct 02, 2007
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
SOURCE: Ice maker not working
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Posted on Mar 31, 2009
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
My KTRC22E kitchen aid refrig. stopped making ice. I replaced the valve that ties into ties into the cold water line. The drinking water in the refrig is working properly. I'm told it may be th
sounds like you have a problem with the fill tube at the Ice Maker. remove the IM and then the back wall ( evaporator cover ) , the fill tube is probably frozen. use a hair dyer to melt ice, be careful, the hair dyer can melt the fill tube and other plastic.
Jan 07, 2012 | KitchenAid KTRS22EM Top Freezer...
Water, but "no ice" in my Kitchen Aid
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 28, 2011 | KitchenAid KSCS25FKSS Side by Side...
Kitchen Aid side by side ksra2scnss00 ice maker not working....Water dispenser is working fine
The simple solution for your refrigerator is to replace dual water control valve.For example if your model was the IKSCS25INSS the replacement part would be the=> W10247725 Water Inlet Valve It also could be your ice maker itself so if the ice slots ar empty fill with tap water and allow to freeze. If the ice freezes and drops into the ice bucket and then does not refill with water then replace the water control valve. If not then it nis possible the ice maker is defective and will need replaced.Not knowing the correct model number I think it wouls better that you call Repair Clinic at 1-800-269-2609 and they will be happy to help you find the correct ice maker. 2198597 Ice Maker Assembly Should you have any questions I will be here to assist you, Thank You, Sea Breeze
believe you have your model number wrong so I will give you this link=> product literature search
Oct 03, 2011 | KitchenAid Superba Architect KSCS25INSS...
It's not making ice. Not sending water to the ice maker. I replaced the filter this morning. Water is dispensed for drinking , but not for the ice maker.
I just replaced the water valve because my water dispenser in the door kept dripping. Google parts for your model and put in water valve. It will cost around $80 for the part. My sic year old did most of thr reacement after watching an online video.
Aug 22, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE AND WATER DISPENSER WILL NOT WORK ON KITCHEN AID MODEL # KSCS25FKSS01
if neither one works that usually is the water valve located on the back of the fridge. Try this manually fill the ice make with a glase of water and check the temp. in the freezer. you can reach in and touch to see if water is freezing in ice maker. see if it dumps the ice then surly the valve is bad
Apr 21, 2010 | KitchenAid KSCS25FKSS Side by Side...
Model KSRJ25C ice maker does not work, the teeth
You need a new water valve. We are Kitchen Aid Specialist and have all parts and supplies for your refrigerator. Just call or email us and we'll be sure to get the right part out to you right away! We hope to hear from you soon. :>)
Sep 09, 2009 | Refrigerators
Aug 02, 2007 | KitchenAid KSCS25FKSS Side by Side...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
