Question about Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts
Marley B2451 wall heater
I put brand new Marley electric wall heater .120 volts with 12 gage wire and 20 electric sercuit braker. the fan is working but it does not have enough hot air. I bought 2 and both have the same kind of problem .
Would you please tell me what is the problem.
Mack
  • wolde43 Feb 20, 2009
    PLEASE NEVER BUY THIS NOISY BRAND AND NOT ENOUGH HEAT EVEN 15X15 ROOM.
These are only 1500 watt heaters.
They 'could' heat a 20 x 20 foot room (with good, tight construction), with a slow temperture rise.
Check the company web site at http://www.qmarkmeh.com/
Doug
Posted on Feb 17, 2009
How do i wire a 240volt hydronic base board heater and thermastat
I need a control knob for my Marley electric wall heater model#fzl3004b
Dec 17, 2012 | Marley Electric Hydronic Baseboard Heater,...
Can I change out a Hayward H400ID with an electric heater for the spa only? If so what electric heater product brand would you recommned. Raypak?
Hayward has manuals for each type heater, gas and electric.
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1___I.htm
Hayward also has contact page, and can probably recommend correct change-over product.
You want to switch from propane to heat-pump type.
There are likely 3 areas of difference. Read each manual and generally look for 1) unit size and capability to match spa 2) pipe connections and sizes 3) Electrical requirement
From electrical standpoint, You need GFCI-protected line from circuit breaker box, or GFCI (arc-fault) breaker. This will prevent electrocution risk around spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
Wire sizes are based on volts and watt-rating of heater.
Each electrical device has rating plate showing volts and watts.
3500 watts divided by 240 volts = 14.5 amps so install double-pole 20 amp breaker and use 12 gauge wire.
1500 watts divided by 120 volts = 12.5 amps so install sinle-pole 20 amp breaker and 12 gauge wire.
http://waterheatertimer.org/Color-codewire.html
Oct 28, 2012 | Raypak Spapak Electric Spa Heater -...
2003 gulf stream prairie schooner 5th wheel computer box/electrical problem
ac runs off 120 volts refrigerator 120 volts heater element 12 volt heater element and control board outside lights 12 volt ceiling fan 12 volts wires that go to box 2 blue furnace 12 volt wires from thermostat 12 volt
May 10, 2017 | RVs
Marley IUH524 Heats but no fan
high limit not working , not letting fan come on try jumping it out to see if it works
Feb 11, 2012 | Marley IUH524 Electric Heater
I have a trailer house that has a 100 amp breaker box in it. I has gas for heat, water heater and stove. I am changing them to electric. Will I need to change the panel put to a 200 amp.
Its probably not a bad idea. Thats alot for a 100A panel to handle, a range needs a 50A, a water heater needs 30A, and the heat will need a 50A or a 60A breaker... Plus whatever else is in the house will be a bit more than the 100A service can handle. But if you don't have the money it will do for a while because for the most part they won't all be pulling at the same time. Word to the wise get at least a 30 space panel when you upgrade, I always install a 40 space panel because for the cost difference its well worth it for future needs because you'll fill it up quicker than you think and you'll have space for anything else you may want to add later on. Hope I helped
Dec 09, 2010 | Your One Source Homeline Circuit Breaker
Marley electric 3ft. basebord ,wiring w/thermostat
If your baseboard heater is rated at 220 VAC and you have wired it to a 120 VAC source then the heater will only produce about 1/4 of its rated output wattage. So, if you have a 2000 W / 240 V heater it will only produce about 500 W at 120 V. You may want to have an experienced technician wire it for you if you are not sure what you are doing. Please be careful and smart when dealing with electricity!!
Nov 24, 2008 | Fahrenheat Electric Convector Baseboard...
Baseboard electric heater installed properly, yet won't work.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
Nov 22, 2008 | Fahrenheat Electric Convector Baseboard...
Detaching heater unit from its mounting
Make sure disconect the sercuit braker off before you remove the heater from the wall. Safty is first !
Aug 29, 2008 | Heating & Cooling
Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts Logo
668 people viewed this question
Top Marley Heating & Cooling Experts
Paul Carew
Ron Durham
Are you a Marley Heating and Cooling Expert? Answer questions, earn points and help others
