Question about Electronics - Others
How to insert memory card into micromax m2 - Electronics - Others
  • 36 Answers
SOURCE: m2 memory card needs formated
insert into your computer, Go to my computer and right click on your memory card. go down to format.
Posted on Jan 22, 2009
  • 11 Answers
SOURCE: Micro M2 memory card adapter
Memory stick flash memory is tricky. If it is too small, DO NOT INSERT IT. I made this mistake and was lucky enough to have some tools handy to get it back out. You'll need a different adapter to use it in the memory card reader that you have.
As for "guest" 's conundrum. You will need to use either needle nose pliers or tweezers to VERY CAREFULLY remove it. It won't be easy and you have to be careful so as not to push it farther in (which eventually it will stop going in, but still makes it that much harder to get it out)
Good luck
Posted on Mar 25, 2009
  • 8 Answers
SOURCE: Stick Micro M2 Memory Card
Don't know the size of the micro with its adapter, but if it is the size of a duo card you should be able to put your micro with adapter into a Pro adapter and this is the memory stick that most card readers accept. Sony has been pretty much backward compatible so I feel this should work. A Pro adapter runs about $10 @ Best Buy.
Posted on Aug 01, 2009
Jack_Dawson
  • 287 Answers
SOURCE: i did a reformat but still my phone cannot detect the memory card
1. If your memory card can be detected on your computer, then try to completely format the card.
2. Goto Start >> My Computer >> Right-Click the memory card icon >> Format >> Uncheck the Quick Format option >>
Start >> OK / Yes (confirm the request!).
3. If the memory card cannot be detected / readed by your PC, phone, or camera, then that card has become corrupt / unrepairable!
4. You should replace that memory card with a compatible one!
please rate this advice if it helps...tc! :)
Posted on Jan 14, 2010
lyonzy1
  • 208 Answers
SOURCE: my M2 micro card is unable to connect.its showing
Please goto google and type:
"Ericsson w580i phone drivers "
Or goto the ericsson website and download the correct software for your phone ( pc connectivity manager )
This should solve your problem
Posted on May 20, 2010
I have forget my Micromax x455 phone code.. Now I acn't acces My memory card & Music Player...
remove the mem card and flash ur mobile and insert ur mem card and use it
May 14, 2014 | Micromax Cell Phones
Pleeze help, ok i insert my memory card reader and computer recognises, fine, however when i insert my 16gb sandisk m2 memory card.....nada, nothing, zilch!?? It says that there is no media inserted and...
This is because there is a fault in the slot where you put the memory card.
The problem is the memory card contact surface in not in contact with the memory card reader contact surfcae.
So please change the memory card reader it wil be fine.
Thanx
Jul 08, 2010 | SanDisk 1GB Memory Stick M2 Memory Card
How to insert sandisk memory stick micro 1gb to computer?
Yes, you will need an adapter unless you have a card reader that accepts that specific type of card.
Dec 05, 2009 | SanDisk 1GB Memory Stick M2 Memory Card
The SD m2 2gb Micro does not work on my phone
the card shows sign of a rom ic being lost its firmware
Sep 05, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
My sandisk m2 does not get regognised on my mobile phone.
You need to isolate the problem. Try connecting the Sandisk M2 into another phone or computer (using an adapter). If this memory card is detected by other phone or computer, then you may want to insert another memory card into the problem phone to test it.
If the problem phone works using another memory card, but the problem memory card also works using another phone, then you may want to format first your Sandisk M2 before using it.
Have a great day!
Aug 16, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Gud evning sir my m2 memory card first worked well in my w200 mobile suddenly my phone i not recogonize or read the memory card but if i put another mmc it reads wats the problem in mmc how to solve pl...
vivek,
try to insert your m2 memory card to other card reader device and check if it can be recognized. then scan for possible virus infection or reformat your m2 memory card.
if still no change, clean the contact pin from your m2 card. use metal folish liquid solutions to clean the copper contact pin of m2 card.
cheers,
mark
Feb 01, 2009 | SanDisk 1GB Memory Stick M2 Memory Card
M2 memory card needs formated
Jan 21, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Good luck
Jan 12, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
