Question about Nokia 3250 Cellular Phone
Where to insert memory card?
Ok i cannot find the slot to insert the memory card....can u show me? in picture form..thankzzz
  • 333 Answers
I believe the slot is under the battery cover. Take the cover off and look on the side by the battery.
Posted on Jan 22, 2009
How to insert memory card in sanyo lcd digital camera vpc x350
The camera, being almost 15 years old, only can hold Smart media memory cards. They are large but very thin.
Your camera should be opened on the bottom and the card slot is like 1 by 40 mm.
I hope I manage to post some pics from the cam and from a memory card.
I only can show a picture from a service manual, so don't do anything with the screws. It only shows where the memory card slit sits. It is the long black line. Should be like 40 mm wide.
Memory card (SmartMedia)
Sep 13, 2014 | Cameras
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
Jun 18, 2011 | Samsung Star GT-S5233 Cell Phone
I have a Dell Dimension E521. I inserted a SD memory card into the SD card slot and nothing happens. The slot is not showing up under My Computer. I'm trying to transfer pictures from my computer to the SD...
check the device manager if it is showing there ? if with an error then u need drivers .. if it does not show up there then there is a problem with the memory card reader ..
Oct 24, 2010 | Dell Dimension E521 PC Desktop
How do i transfer pictures on a samsug sch i760 onto the micro sd card?
    The microSD memory card MUST first be formatted, by the handset, in order for the handset to create the destination folders.
    To transfer the pictures, remove the memory card slot cover. Insert the microSD card into the slot until it locks into place. Press the OK key for menu. Select Get it Now. Select Picture and Video. Select My Pictures. Select desired picture. Press the right soft key for options. Highlight move and press OK. This puts the picture on the SD card.
Oct 22, 2010 | Samsung SCH-i760 Smartphone
When i insert my memory card in the slot than the phone didnt show the memory it tells insert memory card..........
The memory card is not good, please, try and change the memory card and insert it. Thanks
May 20, 2010 | Lands Phones
E66 shows "Remove Memory Card and Press OK" it has latest software and few apps only. pls help
It can happen at two occasions :
1.Memory card not properly inserted.
2.Ur card slot door is not working properly....
Oct 10, 2009 | Nokia E66 Smartphone
How do you transfer pictures on thememory card inserted in the print to the computer?
if you plug the memory card in the slot. software will see it and start automaticly.
May 30, 2009 | HP Photosmart C4480 All-In-One InkJet...
HP C5180 All-in-one : Memory Card Error, No memory card in it
  1. Remove the memory card from the camera.
  2. Locate the memory card slot on the product that is compatible with your memory card. Figure 1: Memory card slot locations c01331721.jpg 1 - CompactFlash (I, II) 2 - Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card 3 - xD-Picture Card 4 - Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro 5 - Front universal serial bus (USB) port (PictBridge-enabled)
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass storage port on your product. These partitions are added by the manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive.
  3. If it is not already on, turn the product on by pressing the power button (c01324469.gif ).
  4. Turn the memory card so that the label faces inward and the contacts face the product. Figure 2: Inserting the memory card c01335108.gif CAUTION: Inserting the memory card in any other way might damage the card and the product.
  5. Gently push the memory card into the memory card slot until it stops. The memory card does not insert all the way into the product; do not try to force it.
  6. When the memory card is inserted correctly, the status light next to the memory card slots flashes and then remains solid green. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. You can safely remove a card only when the status light next to the memory card slots is not blinking. Do not pull out a memory card while the light is flashing green.
Step two: Print the photo
  1. Press Photo Menu . A message displays on the control panel with the number of files found on the memory card.
  2. Press the right (c01185072.jpg ) and left (c01185108.jpg ) arrow buttons to browse through the photos on the memory card.
  3. When the photo number you want to print appears, press OK .
  4. After selecting the photos, press Photo Menu again.
  5. Press the right arrow button (c01185072.jpg ) to select Number of Copies , and then press OK .
  6. Press the right arrow button (c01185072.jpg ) to select Layout , and then press OK .
  7. Press the right arrow button (c01185072.jpg ) to select Paper Size , and then press OK .
  8. Press the right arrow button (c01185072.jpg ) to select Paper Type , and then press OK .
  9. Make any other appropriate changes to the settings, and then press Print Photos .
May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Wont accept xd picture card
Hi, tecnil
Device cannot detect files on the memory card.
Cause
The memory card might be missing or inserted incorrectly. Verify that the memory card is inserted correctly.
The files might not be in the correct format. To print from the device control panel, the files must be in the sRGB JPEG format. To print other formats, you must use a software program on your computer.
You might have inserted more than one memory card. Only one card slot can be occupied for the device to detect JPEG files. Verify that only one card is inserted.
oke,
thx
cropp
Jan 08, 2008 | HP Photosmart 7450 InkJet Printer
Micro memory cards
NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!! IVE GOT 1 THE MEM CARDS 4 THE W580I IS AN M2 MEM CARD LAD
Dec 09, 2007 | Sony Ericsson K750i Cellular Phone
Nokia 3250 Cellular Phone Logo
42 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
