Question about Jcb Bruder JCB Loader Backhoe
WHAT KIND OF BATTERY GOES INTO JCB BACKHOE 212S?
NEED A BATTERY FOR 2003 JCB BACKHOE 212S
2 Suggested Answers
emissionwiz
  • 78936 Answers
SOURCE: Need to know front weight sizes for JCB backhoe loader
Sorry we do not have that kind of information here.
Posted on Nov 28, 2017
Nov 28, 2017 | Jcb Toys
Can't swing the backhoe arm left or right with the controls
The travel lock is either in place keeping it from moving in transport or there is something wrong with the hydraulics. Look for a push button release. The other thing is the stabilizers have to be engaged
Jul 21, 2014 | Jcb Bruder JCB Loader Backhoe
I have a jcb 214s will operate forward&reverse in any gear for approx. 20 minutes then seizes up and won't go either direction. Replaced layshaft-mainshaft valve and solenoids, replaced 4 wd valve and...
Old.
This forum states they are crap
http://www.heavyequipmentforums.com/showthread.php?540-jcb-214s-owners-opions
You should try asking there for more help.
Oct 28, 2013 | Jcb Bruder JCB Loader Backhoe
I need to know where the bleeding screw for brakes on jcb214e backhoe
most of those type of equipment have inboard brakes in the axle tubes of the rear gear assembly i.e. follow your brake lines from the master cylinder to the rear axle assembly,the lines usually go in and to a caliper and another line comes out to a bleeder tip nipple ,some models are actually inside the axle tubes them selves requiring disassembly of the wheels ,axle tubes etc. until you get to the inboard rotors and calipers ,major work for such a minute ordeal this is done to keep the system protected believe it or not,i would obtain yourself a model repair manual if i were you or you could also go to jcb and ask them for a photo copy of the entire brake hydraulic system
Feb 28, 2012 | Jcb Bruder JCB Loader Backhoe
Where i can order jcb 3cx part?
If I talk about India than I can suggest to you a good amount of JCB Spare Parts Manufactures and You can deal all parts Related to JCB And Backhoe Spare parts also Order From Here.
Nov 29, 2010 | Jcb Bruder JCB Loader Backhoe
Gauges don't work, battery goes dead, ignition changed, battery changed, alternator changed problems presists
Charge battery, start engine, then touch the small terminal on the altenator momentarily with a jumper lead from the hot terminal on the alt. Charge light should go out and batery should be getting a charge. why it does that i still can't figure it out, but it works!
Nov 24, 2010 | Jcb Bruder JCB Loader Backhoe
I would like to know the weight of a jcb 1400b backhoe
if it is standard clutch and the weight is 8,550lbs w/converter and 8,430lbs with dry clutch and if equip with extendahoe pwer shuttle is 9,210lbs and dry clutch is 9,090lbs and those weights do not include front or rear buckets of backhoe and loader as this can vary because of the size of bucket equip with. hope this will help you. jcmarleau@aol.com
Aug 29, 2009 | Bruder Mack Flatbed Truck with JCB Backhoe
Transmission on Backhoe
I think you need Check your Transmission Pressuer of your machine. After That Change Recormanded Transmission Oil & Right Quntity. Transmission Pressure Should be 10-12 bar.
Jun 14, 2009 | Bruder Jcb 4CX Loader
Jcb Bruder JCB Loader Backhoe Logo
364 people viewed this question
Top Jcb Toys Experts
Gary Nitowski
jamessizer
jamessizer
Pushkar Singh
Pushkar Singh
Are you a Jcb Toy Expert? Answer questions, earn points and help others
