Question about Tomtom GO 910 GPS Receiver
Switch not turn off
Hello dear, I have tomtom910 i didn't use last few months i put it home charger&connected to computer it has been charge over night now i try to switch it off but it doesnt power go off .it still has power on.can you help me please.
Thank you
Masumur rashid
  • 214 Answers
Yes, I can help you. Just turn it over and look inside where it plugs in. Next to the little gold tips you will see a VERY tiny hole. You have to stick something like a paper clip in that hole & push. This will do a soft reset. You will not lose any information, it will just soft reset. Sometimes you have to do this is you forget to turn it off before disconnecting from PC ect. Good luck. If this helps you plz rate it. Thank you kindly.
Posted on Jan 31, 2009
Hello, i have problem with my Iphone 3g 8gb. The problem is that, that after a few opening it stoped to work. It was not first time when i was opening it because wanted to make camera working well, but...
I would strongly suggest to bring it to the nearest apple store, but try these combinations as well.
1. Make sure your iPhone is connected to its charger for about 20 minutes, see if there's any reaction. The battery may be causing the problem.
2. If that's not the case, keep the phone connected to the charger, press the power button for 10 seconds, then press the home button without letting go of the power button for another 10 seconds.
3. Release the power button, and it should automatically start in DFU mode.
If this does not work, repeat all the steps above now with your USB connected to the laptop, and try restoring it with iTunes.
May 31, 2011 | Apple iPhone 3G
I purchased a Pronto 41 wheelchair and a Winsunny battery charger. The charger didn't have a manual so I'm wondering what the best procedure is for recharging the batteries. Do I need to turn the...
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
May 30, 2011 | Electric Mobility Pronto M41 Power Chair...
I purchased a Schumacher 1200A battery charger a few months ago and just last night tried to charge my 2007 Infiniti G35 battery. The vehicle gets limited use and when I went to start a week ago the engine...
I don't think you did anything wrong. I think your battery is tired and can't take a charge deep enough as it used to. As batteries get older and after repeated discharge and recharge during normal operation, they start losing their ability to hold charge as deep as when new. This is gradual and after a couple of years they drop to 50% and less. I think your attempt was "gallant" and you did everything correct, but it sounds that battery has flatlined on you and "Doc, the patient is gone"
Jan 05, 2011 | Schumacher & Fast Charge Starter Charger
Green light on but will not switch on
plug in your xl via the usb cable to your computer and let it charge a few hours, then press and hold the power button for up to 15 seconds.
do not use the car or home charger to intially charge your xl. they are to maintain the battery, not a rapid charge.
let me know if you need further help.
Nov 09, 2009 | Tomtom One XL GPS Receiver
Tomtom910 not holding charge or charge properly
Looks like the battery needs replaced. Go to: http://www.unc.edu/~bmoc/tomtom/Tomtom%20Go%20910%20Dismantling%20Manual.pdf
This site will give yo step by step how to change the battery. Good luck!!!
Oct 03, 2009 | Tomtom GO 910 GPS Receiver
Tomtom910 won't turn on. I replaced the battery, charged it and now it won't turn on.
Try doing a reset. The reset hole is on the bottom of the TT 910. Use a paperclip to do the reset. Gently push the paperclip into the hole until you feel a click the hold it for 30 seconds. That should do the trick, unless the unit is not actually charging. The green light will come on but not charge because of a bad connection on the motherboard on the negative side.
Jun 20, 2009 | Tomtom GO 910 GPS Receiver
TomTom910 not charging
This is a common problem with the 910. Try putting an obstacle in the way of the wire to keep it on. Better still is to not use the home dock at all. Just plug the home charger in to the windscreen mount (device connected of course!) and charge it that way. You get a better charge and it will stay on.
Nov 16, 2008 | Tomtom GO 910
My Ipod Nano Wont Charge on the wall Charger.
Hello Kawase,
I would suggest you try charging the unit this one time by connecting it to the computer. I suspect that the charger may be defective if plugging the wall charger into the iPod has no effect on the low battery warning. If the iPod is able to be charged from the USB port on your computer that would tend to confirm that the charger is not working. If the iPod does not charge when connected to either the computer or the wall charger then you may very well have a another defective iPod.
Best Regards
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Apple iPod nano 3rd Generation
Nuvi 250
Have you used the wall charger to fully charge the battery? If the battery is too low after lying around for a month it wil not start, giving it a couple of minutes of charging wo'nt help either, a good and full charge will!
Mar 29, 2008 | Garmin nuvi 350 GPS Receiver
Tomtom GO 910 GPS Receiver Logo
69 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
