Question about Philips 60PL9200D Projection Televisions
Philips 60PL9200D/37 60" dlp picture flickering color.
eagle338
  • 4889 Answers
SOURCE: philips tv. model.# 60pl9200d/37. picture
Clear case of lamp failure. When was the last time you have replaced it?
Posted on Dec 27, 2010
taran_2005
  • 10515 Answers
SOURCE: Philips 60PL9200D/37 - dark picture for two weeks
There is a very good chance that we have a bad lamp here again. Which is about the best case for you.
I think the first thing we should do here is take it out and inspect it. We might find that it is shattered and know without a doubt that it needs to be replaced.
Also if you don't know about the lamps in these sets here is some information: These lamps are a "consumer replaceable item" meaning they are made for you to change. This is similar to changing a light bulb in a lamp but allot more expensive and a little more difficult. These lamps last on average anywhere from 1 to 3 years before they need to be changed. They also burn out based upon the number of hours the tv is on and the number of times the tv is turned on in its life. The more you watch the tv the faster the lamp will burn out, and the more you turn the tv on and off the faster it will burn out. There is really no way to prolong the life of a lamp other than not watch the tv, so most people don't worry about it to much and just expect for this to happen ever couple of years.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 03, 2011
dcramer531
  • 1654 Answers
SOURCE: Philips 60PL9200D has sound but picture goes dark
There is always hope, when was the last time you changed the bulb? Although this sounds like an overheating situation, check and make sure all the cooling fans are working in the back, if not replace them or have somone check out the circuit boards that control them.
Posted on Mar 08, 2011
diodeic
  • 1622 Answers
SOURCE: 50 inch dlp philips picture flickers after about
Hi.
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Good luck in solving the problem....
Posted on Jun 30, 2011
  • 8457 Answers
SOURCE: I have a Philips dlp60pl...the picture flickers
No.Do the tv pictures colors back ground flashes black and white when this problems happen?Ur tv now make any humming sound or motor noises?Yes,than the tv colors wheel it is the causes and the problems.The tv colors wheel it is dying and starting to be worn out.The tv colors wheel itself it is starting to come out of the spinning motor axis.The tv colors wheel have to be replace to fix this problems.The tv colors wheel sit way back of the tv,must have to take out many mechanical parts before u can even come to the tv colors wheel itself to replace it.If u have no mechanical skills don't tries to replace the tv colors wheel ur self.Hire a tv Tech. to replace the tv colors wheel it is ur best bet.
Posted on Sep 24, 2011
My 60in dlp comes on but no pic.red light flash 6 times
Check to make sure the lamp indicator light its not on - if so the bulb likely needs to be replaed.
Apr 15, 2013 | Philips 60PL9200D/37 Bulb
I have a Philips 60-Inch DLP Projection HDTV model# 60PL9200D/37 won't power up or down when you plug it in you hear the motor come on but only thing that happens is the power button blinks blue. Real...
Hello
Its main board [motherboard] will have some short circuited component/s. To locate the exact faulty component, you have to check the main board. Normally, DLP control chip are found faulty to this type of sets. You must have through knoledge and expereince to work with this type of Tv circuits, and must have its schematic diagram [service book], all tools to proceed. OK.
Feb 07, 2012 | Philips Televison & Video
I have a Philips dlp60pl...the picture flickers and the color turn red to green then back to normal color, could this be the bulb.
Sep 24, 2011 | Philips 60PL9200D Projection Televisions
Philips 60PL9200D has sound but picture goes dark after maby 30 seconds is there any hope for my tv?
Mar 08, 2011 | Philips 60PL9200D Projection Televisions
Picture jumps red light came on
Need to replace the color wheel on your set.
Dec 18, 2010 | Philips 60PL9200D Projection Televisions
Philips 60pl9200D/37. Two Red lights on power button.
If the power button is displaying the bulb fault indicator AND overheat indicator lights at the same time, it indicates a faulty cooling fan. The television is smart enough to detect when either of the two cooling fans in the chassis have failed, or aren't spinning fast enough. To prevent overheating and damage, the set will not turn on if a fan is faulty. You'll need a replacement fan.
Jun 20, 2010 | Philips 60PL9200D Projection Televisions
How hard is it to change buld for 60PL9200D philip tv could my husband do it himself?
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 16, 2010 | Philips 60PL9200D Projection Televisions
Dlp has no picture only flickering lamp & timer lights.
Verify color wheel is reconnected, color wheel needs to get up to speed before lamp strikes
Jun 21, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Philips 60PL9200D Projection Televisions Logo
113 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
