Question about Galaxy Radios DX- 88HL Base CB Radio
Got pop noise - Galaxy Radios DX- 88HL Base CB Radio
  • 3,287 Answers
Popping sounds are from the the ignition - spark plugs, wires and distributor. Most modern cars have "radio resistor plugs" & "spark plug wires" installed from the factory. If unsure on an older car, check under the hood and inspect the wires & plugs.
Make sure your radio AND antenna system are solidy grounded. Poor grounds can allow all kinds of strange sounds and erratic behavior from the radio.
Also, connect the + & - power leads DIRECTLY to the battery. You can pass the + lead through a dedicated relay that opens when the key is removed if you want, but avoid like the plague connecting the + lead to a terminal in the fuse box and the - lead to an arbitrary grounded point on the body. Direct connections to the battery helps to prevent a way for noise to enter the radio on the power leads.
You may also be hearing the electric fuel pump located in the fuel tank on many newer cars. Solving that sound is very difficult.
Posted on Jan 15, 2013
What causes a popping noise from front end, and a rubbing noise , not grinding
4wd?? Check CV shafts. Also look for whats rubbing. whre is the dirt rubbed off.
Feb 26, 2016 | 2005 GMC Yukon
Yamaha virago noise popping noise on acceleration
This popping noise on cold cylinder may be due to detonation , timing on spark plug ignition should be checked.
May 01, 2014 | 1982 Yamaha Virago Xv920 Xv 920 Y153 Air...
Monitor pop noise
Please clarify what type of pop noise. Audio pop or just a pop noise and the unit may no longer be working?
Apr 23, 2014 | ViewSonic Computers & Internet
Because of Popping noise I replaced the struts. The popping noise is still there, it appears to be the bar that is attatched to the strut popping on the connection below the strut. What is that bar called?
The sway bar is connected to the strut via the sway bar link pins which very commoonly go bad and make popping,rattling,and clunking type noises
Nov 27, 2010 | 2004 Saturn ION
85 Nissan stalling, popping noises.
mcdevito75 here, Sounds as though you have a worn or broken timeing belt, or problem with -in the ignition system of the engine. Have the shop check it out for you.
Feb 21, 2010 | 1992 Dodge Dakota
Popping noise when acceralating
run a compression check could be blown head gasket
Feb 21, 2010 | 1989 Jeep Wrangler
RCA HD50LPW164 turned on TV made a pop
the loud pop you heard was probably a capacitor blowing its top. The grinding noise is likely high voltage arching that was occuring due to rising voltage since capacitor isn't there to smooth it out.
Nov 02, 2009 | RCA HD50LPW164 50" Rear Projection HDTV
Our 10 month old Amana, Model Number Aff2534FEB1, Serial Number KW4932914, periodically makes loud popping noises. It runs and cools just fine. Are these popping noises and indication that there is...
Popping noises can result due to anything from the parts of the box expanding and contracting against each other with temperature fluctuations to the icemaker ejecting a batch of ice. It could even be noises made while the box is going through a defrost cycle. If you catch it making a popping and open the freezer door to hear some hissing and sizzling going on it is definitely defrost noise, quite normal.
Jul 13, 2009 | Amana Refrigerators
Intermittent banging/popping noise.
Freezer is making a popping noise
May 05, 2009 | Refrigerators
Galaxy Radios DX- 88HL Base CB Radio Logo
35 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
