Question about Toshiba REGZA 47HL167 TV
Remove pedestal stand TOSHIBA REGZA 40XV645U 40"
5 Suggested Answers
SOURCE: how to get pedestal off a toshiba 32 HL 67
Take out 5 HEX head screws and one black screw from jack pack cover. the pedestal will slide out from bottom. You do not need to remove jack pack cover as it is part of entire back panel.
Posted on May 22, 2008
SOURCE: taking stand off toshiba regza tv
forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
Posted on May 17, 2009
vinnyq
  • 157 Answers
SOURCE: Toshiba Regza 40XV645U garbled sound
There is an issue with the audio processor. Most likely it is the main board needs to be replaced in order to fix the issue. You will need to remove the back cover in order to get access to it.
There could also be an issue with the power supply supplying the right voltage to the processor. This can be checked by seeing if the 18V DC is present at pins 3 and 4 of CN90 on the power supply. If the voltage is present, then replace the main board. If it is not, replace the power supply.
Posted on Nov 09, 2009
  • 30 Answers
SOURCE: how do I install the pedestal stand for the
the stand just slots into the bottom of the tv and you just tighten it with four bolts provided.
Posted on Nov 29, 2010
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
How do I remove the pedestal from the 42RV530U?
1.) Set the t.v. face down on a flat, but soft or cushioned surface as not to damage the screen. As you face it down, remember to position the t.v. so the stand is sticking out over the edge of the surface you are placing it on.
2.) There should be four screws on the back of the t.v. set near the stand. Remove them.
3.) Once you remove the four screws, you should be able to pull the pedestal stand away from the t.v. set by sliding it out of its holder.
Hope this helps!
Nov 17, 2013 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Can't remove the base/feet - i want to mount on the wall. if there are screws, we can't find them - tried allen wrench, phillips, etc., no luck. thank you
See page 5 of the owner manual:
without tools.
3) Remove the five screws shown in the diagram below. This will
4) Once you have removed all five screws holding the pedestal
http://www.tacp.toshiba.com/tacpassets-images/models/47HL167/docs/47HL167_om_e.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 18, 2010 | Toshiba REGZA 47HL167 TV
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
I want to remove stand from 42 to hang on the wall 1080
Click here to download the user's guide and check page # 5 for instructions on how to remove the pedestal stand.
Jan 02, 2010 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Removal of Pedestal for Toshiba Regza 32HL67U
more than likely it is a Philips and there should be four marked with arrows
Nov 30, 2009 | Televison & Video
Toshiba Regza 40XV645U garbled sound. Have to turn TV off and back on to resolve. Recurrs after an hour or so.
Nov 09, 2009 | Toshiba 40XV645U 40 in. LCD HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Toshiba REGZA 47HL167 TV Logo
55 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
