Question about Brother FAX-8070P Plain Paper Laser
8070p factory reset - Brother FAX-8070P Plain Paper Laser
2 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: BROTHER 8070P
leave the door open and hold down the clear button.
Posted on Nov 25, 2008
Eroor 77 for fax brother 8070p
Open the front panel, remove the toner cartridge and close the panel. The printer tries
to warm up and then it will say to open the panel door. Open the door, insert the toner,
close it and the machine error will be cleared.
Jan 15, 2011 | Brother FAX-8070P Plain Paper Laser
We can send a fax and although there is no phone attached it rings but we are not receiving faxes even though we know they are being sent to us
You are set for MANUAL RECEIVE, when the fax rings, press the START button to receive a fax.
Check the MENUS for AUTO RECEIVE settings.
Nov 25, 2009 | Brother FAX-8070P Plain Paper Laser
Error 77 display in the display
To get into maintainance menu:
Power off (remove cord).
Power on while pressing Menu/Enter Button.
Keep button pressed until boot process is finished.
Press 9 to get into maintainance
9 1 1 = print out configuration list
9 9  exit
If you find a way to reset the drum unit counter please post here.
In many cases the counter seems to shut off the machine although the drum unit is still fine.
Well, maybe they just want to sell new drum units.
Mar 28, 2009 | Brother FAX-8070P Plain Paper Laser
Changed drum and need to reset the counter
Leave door open and press clear/back button. Press 1 for yes -new drum or 2 for no-new drum. Close door and you are finished. Hope this helped.
Mar 13, 2009 | Brother FAX-8070P Plain Paper Laser
Dark papers
are you using brother products or generic. using some generic supplies will cause this problem
Jan 14, 2009 | Brother FAX-8070P Plain Paper Laser
Error 77
Try opening the front panel, removed the toner and close the panel. The printer should try to warm up and then say to open the panel door. Then open the door, insert the toner, clos it and the machine error should clear.
If not ---- power off the printer for 15 minutes and power back on again. If that fixes the problem then OK. If not then go into maintenance mode -
Press and hold the menu/set key while turning on the machine. Wait until it comes completely up before releasing. It should say Maintenance in the display.
If not press function,*,2,8,6,4 within two seconds. It should say maintenance in the display. Or on some machines Menu,*,2,8,6,4 within 2 seconds.Once you get it into maintenance hit 91 to do a parameter reset and than 99 to get out of maintenance.
If this corrects the problem then OK but you may have a failing thermister in the fuser. If the problem happens again then change the thermister. If the reset does not work then either the thermister or the fuser lamp has failed. In rare cases there is a poor connection with the cables to the fuser.
You will have to reset the parameter again after replacing the fuser if you need to replace the fuser or repair it.
Jan 07, 2009 | Brother FAX-8070P Plain Paper Laser
BROTHER 8070P
Nov 24, 2008 | Brother FAX-8070P Plain Paper Laser
Can you tell me where I can obtain instructions for a brother fax machine 8070p lazer please
www.brother.com
choose your country and your mfc/dcp.
download the instructions (manuals + faq) needed.
Apr 23, 2008 | Office Equipment & Supplies
Trouble sending fax from 1 machine when 2 fax machines are on the same line.
I am not an expert but I would suggest to simply diconnect the other one when sending cheeeeeeeeers
Feb 13, 2007 | Brother FAX-8070P Plain Paper Laser
Brother FAX-8070P Plain Paper Laser Logo
56 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
