Question about Canon REALiS X700 LCD Projector
My canon x700 won't turn on?
The projector turned off in the middle of a class. Outlet was working. removed and cleaned filters, vac out dust, plugged back in, still won't come on. It is 4 years old, used less than 30 hours a month
  • 4 Answers
SOURCE: Will not turn on MP830
I just had the same thing happen to me. There was a lightning storm here on Saturday night so, even though I have a surge protector, I assume that it took a surge. HERE IS THE SOLUTION! If you unplug the printer (pull the plug!) for at least 20 minutes (which lets the system discharge)then plug it back in, the system is allowed to reset and will fire back up when you press the power button. I know the above post is 3 weeks old, but I'm hoping this will help other searchers like me as well.
Posted on Aug 27, 2007
old marine
  • 2144 Answers
SOURCE: Canon projector model LV7250
You can download the manual here. Instructions for cleaning/changing the filter are in the Appendix, page 51.
Posted on May 13, 2008
SOURCE: I have the Plug going to the wall and confirmed
I see a power supply issue here. Looks to me your printer power pack is gone bad. You need to confirm this by trying another similar power pack with the printer to be sure. If the printer is portable take it to the store or technical personnel to try another power pack with it. Once confirmed you may have it replaced.
Good luck & God bless!
Posted on Nov 30, 2010
  • 5370 Answers
SOURCE: Hello, Sorry for my bad
Be sure to replace the lamp when the message [Replace with the new lamp.] appears. If you continue to use the lamp after the lamp has reached the end of its usable life, the lamp bulb may shatter, and pieces of glass may be scattered in the lamp case.--------------- POWER Indicator :------When this indicator is green, the projector is on; when this indicator is orange, it is in standby mode.----------- WARNING Indicator:-------- If this light blinks red rapidly, it indicates that an error has occurred, the lamp cover is not attached properly or the projector has overheated. If this light remains orange, it indicates that you have pressed a cabinet key while the Key lock is enabled. ----------- After your lamp has been operating for 2000*hours (up to 3000* hours in Quiet mode) or longer, the LAMP indicator in the cabinet will blink red and the message "Replace with the new lamp."will appear. Even though the lamp may still be working, replace it at 2000* (up to 3000* hours in Quiet mode) hours to maintain optimal projector performance. After replacing the lamp, be sure to clear the lamp counter. Resets the lamp clock back to zero. Selecting this option displays sub-menu for a confirmation. Select [Yes] and press the OK button. ---------- NOTE: The projector will turn off and go into standby mode after 2100* hours (up to 3100* hours in Quiet mode) of service. If this happens, press the INFO button on the remote control for ten seconds to reset the lamp clock back to zero. Do this only after replacing the lamp. --------------- Over-Temperature Protection:------- If the temperature inside the projector rises too high, the over-temperature protector will automatically turn off the lamp with the WARNING indicator blinking (2-cycle On and Off.) Should this happen, do the following: - Unplug the power cord after the cooling fans stop. - Move the projector to a cooler location if the room where you are presenting is particularly too warm. - Clean the ventilation holes if they are clogged with dust. - Wait about 60 minutes until the inside of the projector becomes cool enough. --------------] Now as you mentioned that you have replaced the lamp, so did you got original lamp or used or second hand lamp.Only original lamp is advisable.If you got lamp from ebay sites ,then most of the cases they provide used lamp,and in some cases they dont work.In that case new lamp is advisable.But if you got new lamp and still the same problem then check the lamp cover.The cover which you open to remove the old lamp.If that lamp cover is not closed properly then this problem occurs.If the cover is checked ok then other possibility is temp ventilations dirty.Clean the ventilations,check the internal fan is it running or not running.If its not running then fan is the problem.Its stuck with dirt or its got faulty. But if fan checked out ok and all dirt and ventilations cleaned and still the same problem then try reset procedure.Its mentioned above( press the INFO button on the remote control for ten seconds to reset the lamp clock back to zero. Do this only after replacing the lamp.) .Try reset if still the same problem then its faulty circuit board in the projector. ---------- Click this link for user manual:--- http://www.aboutprojectors.com/pdf/canon-lv-7265-manual.pdf --------- This will help.Thanks.Helpmech.
Posted on Mar 14, 2011
  • 3 Answers
SOURCE: "canon mp600..it's about 4 or 5 years old. It
The Power Supplies for the MP600 burn out over time. They are easy to buy and replace:
My MP600 Power supply died as well. Web searches (including Canon) turned up nothing. Called Canon. To order power supply from Canon, call: 866-481-2569 (credit card over the phone, no on-line interface). $34.49 with tax and delivery.
Note: the power supply has black tabs the you push away from the grey power supply case. One tab in front and one in back. The grey power supply box pulls right out of the printer. The internal connector (six colored wires) pulls straight out (there is no release tab/catch). Use small screwdriver or needle nose plyers to carefully remove. Pull/pry the female white nylon connector. Do not pull on the wires.
Posted on Jul 21, 2011
Red warning light
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 29, 2013 | Sanyo PLCXU355 LCD Projector
Turn off on screen message
  • 2
  • 3
  • 4
  • 5
Oct 28, 2013 | Dell 4310WX Projector
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Canon x700 shut off
I will tell you what worked for me and i am not responsible for anything that goes wrong whatsoever.
I unscrewed the projector bolts for the lamp, took it out safely, then unscrewed all the bolts for the projector casing, be careful not to break anything. And use precaution. Then you will see the projector inside and the entire motherboard hard drive. On the top near a corner you will see two larger black wires connecting to some sort of device, in the center of that little device is a little black button, I clicked it, put it all back together and the projector started. Hopefully it works for you.
Apr 16, 2012 | Canon REALiS X700 LCD Projector
Refridgerator is not working will not get cold
Here is the basic idea on how to keep the refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved by an electric fan or blower in order for that product to work properly. If air movement is blocked the fridge won't get cold, the central air conditioner won't cool enough, the vacume cleaner won't clean as well. Check on your fridge's air movement by inspecting the bottom of the fridge for dust and cob webs. Remove the front bottom clip-on plastic grill. Or also even access the lower back of the fridge by removeing the screws holding up the heavy cardboard cover to see inside. Blockage of air flow will prevent a fridge from getting cold. Just like a vacume cleaner stops working when the bag is filled with dust and fibers.
The air could be blocked by the accumulation of dust and fibers. Look under your fridge if it is cloged, it will look just like the stuff on a dirty central air filter.
Dust and fiber buildup blocking the fridge's air movement from back to front (or visa-versa) of your fridge will slowly (years) prevent how good it cools. The build-up of dust and cobwebs prevents your fridge from cooling (more specifically prevents the heat to disapate from the metal heat disipating fins attached to the metal tubes to be blown off by the fans air). OK! Remedy for a vacuum cleaner REPLACE THE CLOGED VACUUM BAG.
Remedy for your fridge manually REMOVE THE CLOGING DUST AND FIBERS FROM UNDER YOUR FRIDGE. SORRY fridge manufacturers do not provide a dust filter like the vacume cleaner and central air systems manufacturers do. You have to figger out the best way you can clean it. Possibly vacuum with a crevice tool, or use a small brush than vacuum. The extreme would be unplug the fridge ( so you won't get electrocuted) bring a water hose into the kitchen and spray water at cobweb buildup at the bottom fridge, than wet vac the floor then wait 20 minutes to dry before pluging the fridge back into the electric outlet.
When you stand in front of your fridge and you hear the fridge electric motor turn on, the fan will blow air.The fridge
May 30, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freeze and ice maker quit making ice and prevent it to keep food frozen
Here is the basic idea on how to keep the refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved by an electric fan or blower in order for that product to work properly. If air movement is blocked the fridge won't get cold, the central air conditioner won't cool enough, the vacume cleaner won't clean as well. Check on your fridge's air movement by inspecting the bottom of the fridge for dust and cob webs. Remove the front bottom clip-on plastic grill. Or also even access the lower back of the fridge by removeing the screws holding up the heavy cardboard cover to see inside. Blockage of air flow will prevent a fridge from getting cold. Just like a vacuum cleaner stops working when the bag is filled with dust and fibers. The air could be blocked by the accumulation of dust and fibers. Look under your fridge if it is cloged, it will look just like the stuff on a dirty central air filter.
When you stand in front of your fridge and you hear the fridge electric motor turn on, the fan will blow air out the bottom.The fridge
May 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge running warmer than it should, Cooling fan on back doesn't turn, the compressor/condensor running very hot , and no new ice being made. Cleaned the cooling grid which was full of dust.
Apr 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The projector turned itself off after couple hours of use and the Temp. red light came on. Power Light turned red instead of orange as usual. After 3hrs I turned it back on, cleaned the dust off the fan...
There are three temp sensor inside the projector and now your projector need full service but if the air filter becomes clogged with dust, the internal temperature of the projector will rise, the TEMP indicator will illuminate and the projector's power will turn off (the TEMP indicator will flash after the power is turned off) The air filter should be cleaned every 100 hours of use.
If you clean the filter with a vacuum cleaner to clean off any accumulated dust. then your projector working normally
Jan 03, 2011 | Panasonic PT-LB50U Multimedia Projector
Displayed massege to check air flow
With most projectors there is a foam air filter behind a grill that is the opening to the cooling channels. A fan ensures air flow to cool the lamp, etc. This filter prevents dust from gumming up the works (and depending on design) may prevent dust getting into the optics. As the filter gets dirty it gradually cuts off the air and at some point a protective circuit kicks in and turns off the lamp.
If the projector is on you will feel a stream of hot air coming out of the exit vent. Projectors vary in terms of amount of air flow, so its difficult to define what is normal for a specific model. However, you can simply hold a hand in front of the vent and see if there is air flow (It will be hot air so, careful). If there is a "good" stream of air things are fine, but if only a very light flow is felt the filter may be dirty.
If the filter has not been cleaned or replaced recently make sure the projector is turned off and cooled down then take off the inlet cover and remove the filter. Clean or replace per the instructions for the projector (and periodically as defined .. but taking into account the operating conditions). Once cleaned turn on the projector and feel the "normal" air current for future reference.
Heat is one of the major causes of projector failure, so make sure cooling vents (inlet and outlet) are not obstructed and filters are kept clean
Oct 02, 2006 | Hitachi CP-S240 Multimedia Projector
Canon REALiS X700 LCD Projector Logo
old marine
old marine
