Question about Savin Office Equipment & Supplies
How do I wipe the hard drive from a SAVIN 2545 Copier manufactured in 2002?
    New Friend:
    Problem Solver:
  • 9 Answers
You can use aomei partition assistant, it is free and has the feature erase hard drive, you can see this tutorial: http://extend-partition.com/help/wipe-data.html
Posted on Jan 16, 2013
Cogz
  • 1326 Answers
SOURCE: Savin 2545 copier error code sc541
Hit the yellow botton ( Reset/ CA), then 1 then 0 then7 , then hold down the (Stop) botton till the display changes... Then turn the copier "OFF" then "ON" it may clear the code. The code has to do with your fixing unit.
Posted on Jul 22, 2008
  • 990 Answers
SOURCE: Functional problem with the copier (Savin 2545) Service Code SC 546
Hello sir; Your machine need to reset, the procedure as follow;
1, press "clear mode", "107", then hold down "clear/stop" key, until screen change message to sp mode.
2, turn power off and back on ,machine will in working condition.
Posted on May 29, 2009
Ickoajnc
  • 183 Answers
SOURCE: Savin 2545 throwing error code SC672.
Open the operation panel the cable which connects the controller and the operation cable might be not good attached or something like that.
The operation panel you might open by unscrewing the two screws on the front of the control panel and then pull the panel towards you.
Inside you will see some cables see if they are good connected or just disconnect them and connect them again.
If that not fix the problem than you have problem with the controller.
You might do the same procedure like with the panel.
Just remember to turn off the machine before you
pull out the controller.
The controller can be pulled out by unscrewing two screws on the left back side of the machine where you connect the machine with computer you cannot miss that part because the hole machine is with white plastic and that part of the machine is metal part.
Posted on Jul 15, 2009
SOURCE: service code 990 savin 2545 copier
If changing the cylinder, developer and blade the problem is not solved, proves to resetear software pressing by more than 10 seconds the point (.) and the numeral (#) both simultaneously, until it is extinguished and it returned to ignite the machine, this resetea software. If the problem persists, then the problem can be in the hard disk, replaces hard Disk.
Si cambiando el cilindro, revelador y cuchilla no se soluciona el problema, prueba resetear el software presionando por más de 10 segundos el punto (.) y el numeral (#) los dos a la vez, hasta que se apague y vuelva a encender la máquina, esto resetea el software. Si persiste el problema, entonces el problema puede estar en el disco duro, reemplace el Disco duro.
Posted on Aug 27, 2009
SOURCE: error code sc726 savin copier 2545
Tray shift does not finish within the
specified time after the shift motor
turned on, or the stack height sensor
does not activate within the specified
time after the shift tray lift motor turned
on.
Shift motor defective or overloaded
Shift tray lift motor defective or overloaded
Review the exit tray that this or placed becomes sometimes broken the plastic supports, is offed-hook and it does not get to touch the top sensor, repairs or it changes the exit tray…
Good luck…
Posted on Nov 05, 2009
Does the savin 9122 have ahardive
It may be an optional Hard drive. print the Printer configuration list and see if its listed. UT>printer feautures> config list
Nov 02, 2011 | Savin 2070DP Black and White Copier
We have a Savin 2545 copier. We received an error message SC 726. Can you give me some idea what we need to check?
That error is for the shift tray motor in your finisher where the copies come out. The tray should move from side to side when you switch the machine off and on. It sounds as if it is binding for some reason.
Mar 14, 2011 | Savin 2545DP Black and White Copier
Savin 2545 communicating light blinks but nothing prints
YOU NEED YOUR FIRMWARE UPGRADED BUT ONLY A SERVICE TECH CAN GET IT AND DO IT.1 HOUR OF TIME SHOULD BE PLENTY AND THAT SHOULD INCLUDE A CLEANUP PROBABLY ABOUT 150 TO 200 DOLLARS
May 18, 2010 | Savin 2545DP Black and White Copier
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
I have a recurring problem with a SAVIN 2545 at only one of my customers. The toner will clump & harden in the waste toner transfer box on the front end of the image unit. This prevents the fresh toner...
I've never seen this problem, even in damp environments. Are you sure it's not a problem with the PCU's toner supply mechanism or with the dev unit's auger?
Is it a customer who runs a very low volume? I've seen problems with the toner clumping behind the cleaning blade, but never on the front side of the PCU like that. You might want to try asking around in Ricoh's tech forum, found on the Ricoh website:
http://www.tscweb.net
Feb 08, 2010 | Savin 2545DP Black and White Copier
Savin 9945DPE cannot Network print
Did you format the new drive through the service mode on the copier? As long as the drive is compatible then it should work once you format it.
Jan 03, 2010 | Office Equipment & Supplies
Service code 990 savin 2545 copier
Aug 03, 2009 | Ricoh Aficio 450 Copier
May 29, 2009 | Ricoh Aficio 450 Copier
Jul 20, 2008 | Ricoh Aficio 450 Copier
164 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
