Question about Health & Beauty
Replacement of a broken ejector on a remington versa max
Remington hc 600
You will find a replacement charger for model HC-600 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/cords-chargers-and-stands/remington/remington-hc-600-charging-cord.html
Dec 30, 2013 | Remington HC-600 Hair Trimmer
Fix broken ejector handle
You need to obtain a replacement flash ejector handle first. If you open the router out, you can push the broken ejector handle out with a small flathead screwdriver, it just slides out forward toward the face of the router if you apply a bit of pressure. Then you just slide in the new ejector handle, which is "keyed" on one side. There is also a small metal lever pin that you need to line up with the spring hole when sliding the new ejector handle into place. Once inserted is will snap gently into place and you are done.
<a href="http://www.ciscobuy.com">Sell Used Cisco Equipment</a>
Mar 15, 2012 | Cisco 2801 Router - 2801
BROKEN PLATE, BEARING
Remington saw is out of business. Look online for any dealers selling parts for these saws. Motor brushes are especially hard to track down and prone to break. Hope this helps!
Jun 12, 2010 | Remington 16" Electric Chain Saw
The cablecoming out of the charger has broken
If you need a new charger cord, you can purchase a replacement from shaveroutlet.com. See link below
http://shaveroutlet.com/remington-hc-600-charging-cord.html
Apr 07, 2010 | Remington HC-600 Hair Trimmer
Pop up trimmer stopped working Remington R830
Make sure you are using the trimmer with the shaving heads on the shaver. With heads removed, the trimmer on the back will not work properly. If thats not the problem, the trimmer is broken or jammed. clen the blades really well with a toothbrush and rubbing alcohol. If they're jammed, this will probably free them up. If that doesnt do it, the trimmer is probably broken and that part is no longer available from Remington. If you really like this model, you can find a replacement at shaveroutlet.com
Jan 10, 2010 | Remington Health & Beauty
Broken extractor housing on Remington 870
http://www.brownells.com/.aspx/pid=653/Product/REMINGTON_870_RIVET_STAKING_TOOL_SET
Dec 29, 2009 | Remington Sport & Outdoor - Others
Ice maker gear tabs RS25AGXNQ01
not worth getting a repair kit for the gears, i reccomend purchasing the entire ice amker as a whole, replacing just the gear wont correct the reason that it craked in the first place
Feb 19, 2007 | Roper RS25AEXLQ Side by Side Refrigerator
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
