Question about Sanyo PDGDXL100 2700 ANSI Lumens DLP Video Projector Projector
Dmd chip number pdg-dxl100 - Sanyo PDGDXL100 2700 ANSI Lumens DLP Video Projector Projector
Is there any possible way to repair a DMD chip with tiny white dots?
Anything is usually fixable. What you have to determine with Dell's assistance is if it is cost effective to do so.
Nov 26, 2015 | Dell 1209S DLP Projector
My Sanyo PDG_DX100 projector only 100 hours now, its started white dots and balck dots how to fix it. if DMD chip problem, how much it cost me.
Sanyo PDG DXL100 1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD200 We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. any questions, feel free to contact me have a nice day! Jerry Lampdeng Limited
Jul 23, 2014 | Sanyo Office Equipment & Supplies
Does anyone know the part number for DMD chip in Acer X1260 projector?
Hello i got issue with white and black dots on ACER X1260.
The orignal parts was a 1079-6319W...
I tryed to put on a 1079-6329W supposed to be compatible.
I got white vertical lines on screen and no more pixel dead, this reference seems not compatible ( i think its 18W->19W ; 28W ->29W only).
I tryed to clean up with KF special contact F2, chip pins, socket, cards connectors, but nothing worked, still vertical white lines with 1079-6329W chip ( instead of 1079-6319W).
I hope this can help everyone in trouble with Acer X1260 and other.
DMD chips are not so compatible !!!
Sep 07, 2013 | Acer X1261 DLP PROJ SXGA 37001 Multimedia...
Is dmd chip all same for dlp projectors?
no they are not type in dmd chip in serarch engine one option will probably come up something like albinia.com they have many different chips you will need to get yours out to find the number on it if you are not familiar with dissasembling simalar electronic devices may be more than you are looking to get into also even used chips that i have seen for sharp projectors run about $125 bucks
Dec 06, 2012 | Office Equipment & Supplies
I have white dots on the picture
You have a bad DLP/DMD chip. You'll have to have it repaired. You may be able to do it yourself if you are handy. Cost a few hundred. You might be able to get the part from Sanyo it will cost more. Many DLP chips have a three year warranty. I have done it to some mitsubishis I pulled one apart and got the chip number then ordered from China.
http://www.youtube.com/watch?v=V_uUH-xHKkU
Dec 03, 2012 | Sanyo PDG-DSU21N Projector
Need a dmd chip for Benq Joybee GP1
It's chip number 8560-502AY.
It's hard to access. Remove two screws rear of case and two screws bottom of case to remove the lid. Remove three large screws from mainboard - one at the rear in front of the input port, one to the left of the projector lens, one deep below some blackout tape in the front center of the board. The entire mainboard assembly will now come out. The DMD sub board is to the left of the lens. One screw on the bottom holds it to the main board. The DMD subboard can now come carefully off its connector. The DMD can now be popped off the front of the sub board by using guitar pick or similar.
Sep 14, 2012 | BenQ Joybee GP1 DLP Projector
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
Samsung hl-t4675s white spots on screen started now screen is almost black lost pixel what is cause
My Samsung LCD has white spots on the screen. The tiny spots seem to be increasing in numbers. I am outside my warranty. Is this going to cost a lot. It is a 43in screen.
Jul 16, 2009 | Samsung DLP HL-P5663W 56" TV
Sanyo PDGDXL100 2700 ANSI Lumens DLP Video Projector Projector Logo
238 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
