Question about Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black
How to Set flow amount on Bunn STF-20 - Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black
3 Suggested Answers
  • 125 Answers
SOURCE: How do I set the amount of water dispensed w/ Bunn CDBCF35 Digita
Hello. You will need to set the timer, this is done, if the settings are not locked out, using the brew button on the front, holding it until 3 clicks are heard, then just let it brew until you are satisfied with the level, and turn the brew off. This does take a little practice, and may need to be done repeatedly, and you should be prepared for overflowing, just in case :) Here is a link to your manual, please read the section that is for your unit, as it is for several.
http://www.bunnomatic.com/pdfs/commercial/manuals/29079.0000.pdf
Hope that helped, thank you.
Posted on Mar 15, 2009
  • 124 Answers
SOURCE: Bunn-O-Matic Model STF 20 is making loud noises
You may have a thermostat problem.
Contact a Bunn service center and have the unit checked.
Posted on Jan 03, 2010
Bunn hot water heater has a slow flow of water
Try brewing a few pots of white vinegar solution, no coffee in the system.
Jan 22, 2013 | Bunn 125000024 Hot Water Dispenser 5...
What is the best way to clean a Bunn STF-20 coffee maker. It has a water line connection,
Clean with white vinegar, run it through 3 times, then you are set.
Oct 09, 2012 | Refrigerators
I have a bunn auto brew w/2 warmers.flow control/filter is installed and the basket overflows...
Either the coffee grind is too fine, too much coffee or incorrect sprayhead. Count the amount of holes on the sprayhead.
Aug 29, 2010 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Keeps spilling over during brewing
These tanks can't actually be overfilled since all water poured in displaces the exact same amount of water coming out the spout. So, whatever amount of water you pour in, will be the same amount of water that flows to your pot minus the amount absorbed by the coffee grounds and filter.
Your problems sounds like an undersized (Non Bunn) filter, or clogged brew basket. To verify this, try pouring in only half the water for your brew cycle and wait for it to finish dripping, then pour in the rest. If no overflow has occurred, you simply have the wrong type of filter. If overflow begins again, you have a clogged brew basket, since no Bunn can flow too fast for the brew basket to keep up with it.
This is because Bunn filters are manufactured differently than generic store bought paper filters. They will flow faster, brew cleaner and stand up better than normal generic filters.
Remember, Bunn makes their OWN filters for good reason.
They made the first, best paper filters for drip coffee pots, and all others are just generic dioxin gas producing paper.
Mar 05, 2010 | Bunn VPR Coffee Maker
Bunn-O-Matic Model STF 20 is making loud noises and spewing water after brewing is complete
Nov 07, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
I BOUGHT A USED BUNN COFFEE MACHINE STF-15. IT CAME WITH THREE POTS THAT HAVE THE NAME ELLIS COFFEE ON THEM. PART #2097 0202. WHEN I RUNS IT THE POT OVER FILLS. DO I HAVE THE WRONG POT OR IS THERE AN...
This is usually the result of an incorrectly set timer (see p. 22 & p. 24 of manual) or stuck solenoid valve (p. 18). A link to the owner's manual is provided below. You should read the manual thoroughly before attempting adjustments & repairs.
http://www.bunn.com/pdfs/commercial/manuals/29251.0000.pdf
I hope this helps!
Oct 20, 2009 | Coffee Makers & Espresso Machines
Set flow amount on Bunn STF 35
Remove the top panel and look for the yellow float, this controls the amount of water brewed, to adjust remove some of the washers on the float and test until you get the amount needed.
Jul 24, 2009 | Coffee Makers & Espresso Machines
I have a STF-35 , brews more then the pot , can you adjust the amount of water per brew ?
Yes, but you need the pre weighed grommets from bunn, if you remove the top panel on the machine you will see the brew tank, within that there will be brown plastic shaft with a yellowish cylinder on top of it. There might be 3 or 4 washers on top of that yellow piece, those are the weights, when the water fills the tank it pushes the float up and when it reaches the top it turns off the solenoid. You should be able to try it without the top on.
Jun 24, 2009 | Coffee Makers & Espresso Machines
I own a bunn and my brother's business owns 2 of these. The rule of thumb as he was told by the salesman is 2 oz of coffee grinds per 48 oz of water.
Jan 23, 2008 | Bunn VPR Coffee Maker
Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black Logo
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
