Question about Pitney Bowes Imagistics 4845 484-5 Toner For Ix2700 Ix2701 Fx2100 Sx2100 Mx2100 6
How to stop a incoming fax
We need to stop this big fax comming through of 344 pages long as we have urgent faxes
Error 386
Hi Error 344,
Is telling you the remote end has hung up the call which means it may not be a fax number (you called a voice line number for example, you can confirm if it as fax by just calling the number on your phone if you hear the whistles of a fax then that's not the cause).
I'm not familiar with the HP model but if it is "Super Group 3" (you can tell this if the transmission speed is capable of above 14.4kbps) and you're trying to call an older fax the remote machine may not be able to recognise the "Calling tone" your machine is sending and so it hangs up. You can try to remedy this by temporarily disabling Error Correction Mode (ECM) in your machines fax set up menu this will disable the Super Group 3 capabilities of the fax and maximum transmission speed will be reduced to the older Group 3 machine. HP website recommends the following:
Error Code: 344, 345, 346, 347, 348, 349 ECM, 350 ECM, 351 ECM, 352 ECM, 353 ECM, 354, 355 Definitions
  • The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote user pressed the Stop key while the reception was in progress.
  • Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jan 23, 2014 | HP Officejet 6600 e-All-in-One -...
When I fax I get an error message 344* What does this mean and how can I get the machine to fax 5 pages at a time?
Solutions
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved. Click here for instructions on enabling and disabling ECM (c00060802) (in English).
Dec 16, 2010 | HP Officejet 6500 Wireless All-in-One...
CAN THE MEMORY BE LEAGNTHED ON HP1020 TO HOLD IN MEMORY MORE FOR INCOMING FAXES OR ELIMATE HOLDING RECEIVE FAXES AND PRINT PAGES AS THEY ARE RECIEVED INSTEAD.
I found the manuel on line and found out how to print the faxes in memory to release the memory. So next time a big fax comes thru I will try to print and release faxes from memory.
Nov 13, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Fax error 344 - HP officejet 4255 all-in-one
fax error is remote machine not responding to your fax.the other fax has stopped communicating.this is a comms error.
Jun 29, 2009 | HP LaserJet 3050 All-In-One Printer
Error code 344*
Error code344 shows that The remote machine has failed to respond to a fax command from the product because the connection was interrupted.The remote user has pressed the Stop button while the remote machine was receiving.
Under rare conditions, incompatibility between the two machines can cause the remote machine to simply abandon the call.
check here for more information
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00062808#A5
Jan 26, 2009 | HP Officejet 4315v All-In-One InkJet...
Trying to cancel incoming fax on panafax uf-8000
there is a feature called junk fax that will stop all incoming faxes
Jan 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
HP 1010 fax - only receives first pages of a fax
Do you have DSL, or any other type of digital phone line.
Usually this is caused by a "noisy" phone line; some sort of interference.
Sep 23, 2008 | HP 1010 Plain Paper Inkjet Fax
Wont recv.faxes but will fax out,which setting do i use for incoming/out faxes
sir,
check the connection and the settings or try to read the manual
yours,
alecz
Apr 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Pitney Bowes Imagistics 4845 484-5 Toner For Ix2700 Ix2701 Fx2100 Sx2100 Mx2100 6 Logo
29 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
john h
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
