Question about Canon PowerShot A310 Digital Camera
Camera has a problem
When i try to take a picture, I open the lens cover and my screen just flickers and then goes a gray color... All the icons are there and you can see the pictures i have taken on my card. Just happen this weekend..... Any help???
    Genius:
  • 2,985 Answers
Canon Technical Support for this one. This is possibly a known issue and warrants a replacement camera.
Posted on Jul 05, 2007
SOURCE:
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
Fixing the picture in my Philips rear projection tv
As far as mostly red--turn color to zero and examine screen--if not gray or black and white it may need the screen controls adjusted.
Dark---with back cover off clean the three lens this model has--they are the light source for your picture and if dusty picture will be darker and somewhat dull looking.
Answer is based on brand/model number listed here.
May 16, 2012 | Philips 50P8341 50" Rear Projection...
My screen is blank can not see anything
do you have the lens cover open? do you get any error code or warning message? do this: make sure you have fully charged battery. close the lens cover.make sure cam is off.open lens cover by sliding it down until click is heard.if no go.close lens cover.make sure cam is off.remove the battery from cam for at least 15secs.reinsert battery.open lens cover until you hear the click.if no go try this. can you see the operational buttons and icons on the screen? if you do try to initialize the camera. touch HOME ->settings (looks like a toolbox icon) -> Main Settings (touch OK) -> [Initialize] -> [OK]. if it doesn't work service might be required.thanks :)
Mar 19, 2010 | Sony Cyber-shot DSC-T9 Digital Camera
Tv went grayscreen, flickering. turned off, then
When you had gray screen and flickering you had only one problem - color wheel. After "putting everything together" you have totally different problem, caused by multiple possibilities like: forgotten connectors, cut/jammed cables/wires, lamp not being inserted properly, lamp door not being set properly, disconnected color wheel, etc. Try to open rear cover and redo what you have done. Remove optical block, check everything visually and slowly put everything back. If still no luck - then only skilled TV repairman may (or may not) help.
Mar 10, 2010 | Samsung Televison & Video
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
LCD screen displays settings only. Won't take pics
This sounds like a defective CCD that Canon is repairing free. Go here for more details: http://www.imaging-resource.com/badccds.html
Nov 10, 2008 | Canon PowerShot A75 Digital Camera
I need the color adjusted
1)Remove rear cover..clean RGB lens with soft cloth....
replace cover...........
2)Remove front speaker grill & access panel.....
locate RGB screen control block.....slighty adjust RGB
for best color mix.......check B/W tracking by reducing
customer color control to minimum....does pix look gray ?
touch up RGB screen again.....then increase color to middle
of range.....how is that ?......................................T.
Feb 21, 2008 | Televison & Video
Canon PowerShot A310 Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
