DRIVE PARA HARD DISC SAMSUNG SV 160 4E
7 898521 232221 HD 160 GB SAMSUNG
  • Mido Moh Aug 30, 2015
    good day samsung
Goodday gfgfjhjhggkh
Posted on Aug 30, 2015
Drummernick
  • 440 Answers
SOURCE: 500 GB hard drive
well what os are using sum dont aloow more then 200 gb xp partion it in 4 ways ntfc
Posted on Feb 06, 2008
Arius
  • 446 Answers
SOURCE: samsung sp 8004h samsung hd
how many physical hard drive you have if you have only one, chances are you have formatted this and devide the hdd into two, thats why you can see only 30gb on it, just for clarification...
Posted on Sep 17, 2008
SOURCE: Maxtor One Touch II - installation Software
I have a disk that worked for me and I am running windows xp. I also have the website address that is supposed to have the 98 drivers which could work perhaps. http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Maxtor_OneTouch_Drive_USB/Win98SE_Driver&vgnextoid=b07d8b9c4a8ff010VgnVCM100000dd04090aRCRD
Guess you could try them first and if that doesnt work I could perhaps make a backup of the disk/package/mail/ worth anything?
Posted on Apr 02, 2009
  • 41 Answers
SOURCE: cannot access hard drive
You can try full formatting the harddisk and run scandisk and defragment the disk.Hope this would solve your problem.
Posted on Feb 14, 2010
  • 28 Answers
SOURCE: I have a Samsung SpinPoint P80 SP1604N 160 GB Hard
depends which BIOS version you got pal, check your BIOS and evtl flash it.
be careful, them models little tricky when flashing...
greetz
Ganimidis
Posted on Mar 04, 2011
Tradução do português para
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test or replace all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Jan 08, 2011 | Seagate Barracuda 7200.10 500 GB SATA Hard...
External Buffalo Hard Disk 500 Gb model no HD-PF500U2/BK-AP not detecting when connnected to a laptop or a desktop PC
Check the usb port function in the computer bios settings and be sure that it is set to yes. Connect properly your external drive. If it has two wire usb connections, use both to obtain the maximum power that will be need by your drive.
Dec 18, 2009 | Buffalo Technology 500GB DRIVESTATION...
I dropped my laptop, recovered the hard drive and purchased an identical replacement laptop. When I power up with the old HD I can hear a click-click-click and the laptop doesn't recognize the presence of...
The HDD is damaged.
No, it is not possible to transfer the disc to another HD case. First, HDDs are assembled in clean rooms because minute specs of dust can ruin the disc; Second, the disc has addresses on it that correspond to the firmware on the drive
Nov 06, 2009 | Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard...
New hard drive reloading oc
Hi Amy,
It really depends if the notebook is capable of supporting 160 gb HDD or not.
It case it is cabable call Hp and order anew set of Recovery Cd and it would work fine.
Apr 27, 2009 | HP (PV944A) 160 GB Hard Drive
Samsung sp 8004h samsung hd
Sep 04, 2008 | Samsung SpinPoint SP8004H 80 GB Hard Drive
Samsung F250
the manual has instructions on it on how to perform this. do you still have it?
Apr 01, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
HD SIZE
Well it is possible that you partationed the hard drive
if you dont see a c drive and a drive in your system it means the rest of the hard drive isnt in use..
if you see it and ou only have 1 hard drive then it is in use..
IT SHOULD SHOW UP AS
LOCAL DISC C
and
LOCAL Disc D
what you need to do is format your computer, remove all partations and just instally directly on yout hard drive without partitioning it :)
regards and best of luck for the new year
Jan 05, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Drive terminators
Translate from portuguese to english... Meu HD também estava com este problema, o que fiz foi limpar o contato que liga a placa lógica do HD ao leitor do disco rígido que estava oxidado. O problema ficou resolvido.
Dec 27, 2007 | Samsung (SP0411N) 40 GB Hard Drive
Samsung SpinPoint SV1203N 120 GB FHD
Try increasing the actual partition to the capacity numbers in the windows xp formatting , and also format the hard drive using NTFS .
Dec 08, 2007 | Samsung SpinPoint V80 SV1203N 120 GB...
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
