Question about HP DesignJet 450c InkJet Printer
Cutter Problem I have a HP DesignJet 450 C, When i'm plotting a page there is a problem. When plotting a page the cutter comes in and cut's a view lines of 1 meter, about 5/6 times. I get a A1 page with 5/6 lines trough it. Who can help me fix this problem so I can plot a page with out the cutter disturbing it.
  • 53 Answers
You need to lubricate the shaft that the carrage runs on. If you dont have the correct lubricant, use sewing machine oil. Switch the machine off and using a cleaning fluid such as methelated spirits or benzine, carefully clean the shaft. Take care not to damage the encoder strip (plastic strip running just above the shaft, its also sharp, dont cut yourself) Also clean the outside of the bushes on either side of the head unit. Then with your hand move the head unit to the middle of the machine and put ONE drop of oil on either side of the head making sure you dont mess any and also making sure it goes to the back and front of the shaft. Move the head slowly left and right, spreading the oil outwards. If necessary use a second drop but do not over oil the shaft under any circumstances, the more oil the more dust builds up. This will solve your problem.
Posted on Jan 29, 2009
Paper cutter
You should try replacing the cutter assembly with a new one. They are rather inexpensive ($50) to purchase and easy to install.
The only other thing I can think would cause your problem is if something is stuck in the groove by the cutter guide that would cause it to disengage while cutting.
Jun 07, 2013 | HP DesignJet 500 InkJet Printer
Can't find cutter. could it have fallen into machine. the clip that holds it is there. This happened after trying to clear a paper jam
Cutter unit having press & release system, by mistake its released, it might be fallen in paper bin.. You can see there is a cut at right side near blur lever,pull cutter bush up to there & load the cutter into cutter bush. Once hearing click sound manually confirm its fixed properly or not.. once its confirmed, push cutter in to park area, power on the printer..
Aug 01, 2012 | HP DesignJet 500 InkJet Printer
The paper cutter on the Designjet 130nr jams all the time. Help? Where are the screws for the cutter?
from memory this cutter is removed by removing the side cover and sliding it off the end of the carriage rail.
Aug 15, 2011 | HP DesignJet 130NR InkJet Printer
Is not cutting and cutter is on, also, it is printing double lines
Fault: Double line & paper is not cutting.
>Check encoder strip, any damage or dirty?
>Clean encoder strip, replace it..
Reason why its not cutting?: Carriage moves to left side to lock & bring the cutter to cut the paper, but if its not reaching proper calculated destination due to dirty or damaged encoder, it wont lock the cutter to bring it out result paper wont cut even cutter in on condition..
Mar 04, 2011 | HP DesignJet 500 InkJet Printer
DesignJet 5500PS InkJet Printer WILL NOT CUT THE
check the media you have selected. if you have the wrong media selected, the cutter will not work.
Nov 03, 2009 | HP DesignJet 500ps InkJet Printer
Cutter Problem
the cutter has that bushing attached to act as a tire as it travels across the scan axis, these infrequently wear out and cause the carriage to basically drag the blade behind causing your uneven cut pattern, the cutter must be replaced. If you need direction on how to do so please contact me
Apr 16, 2008 | HP DesignJet 1050c InkJet Printer
HP DesignJet 450c driver for windows vista
THIS SOLUTION IM ABOUT TO TELL YOU IS IN MY EXPERIENCE THE EASIEST ONE JUST DOWNLOAD THE WINDOWS XP DRIVER FOR THE HP DESIGNJET 450C PRINTER AND INSTALL IT INTO THE WINDOWS PRINTER PLATTFORM, YOU MAY SEE SOME ANOUNCEMENTS FROM YOUR COMPUTER TELLING YOU THAT THE PROGRAM YOUR TRYING TO INSTALL MAY NOT BE COMPATIBLE "DONT LISTEN TO THEM" JUST CONTINUE YOUR INSTALLATION AND PRESTO YOUR DESIGNJET PRINTER WILL WORK PERFECTLY
Feb 20, 2008 | HP DesignJet 450c InkJet Printer
HP DesignJet 450c InkJet Printer Logo
122 people viewed this question
Ben Johnson
