Question about Precor 9.21 Treadmill
Where is the safety switch for a precor 9.25i tredmill?
My Precor 9.41 si treadmill won't let me click the switch to the "on" position. When I go to push it to the "on" position, it resist and spring back to "off".
is the safety key inserted as there may be a connection to not allow the unit to operate unless the key is in position
Dec 03, 2016 | Precor Exercise & Fitness
Grandchild lost my safety switch for Precor treadmill , manufacturer no longer carries this model. Any work around available?
Hi Emily, The safety switch... If that's the plastic part with the steel plate inside it that attaches to the console and when you remove it the treadmill won't operate then try cutting the top off a can and using that until you find the safety switch...Good Luck.....CHEERS..
Apr 13, 2016 | Precor Exercise & Fitness
Looking for a replacement safety key for my reebok tredmill
Best place to check is ebay.
http://www.ebay.com/sch/i.html?_nkw=Nordic+Track+Reebok+Treadmill+Safety+Key
Jul 08, 2014 | Exercise & Fitness
Belt won't move. It says to reset safety switch. Can't find the switch
There is a red magnet or insert that it used as a safety key. If you lost it, you will need to buy another.
Mar 04, 2014 | Precor 9.21 Treadmill
Precor 9.35 Error 5
please see the details and proceed according. God bless you
Dec 12, 2012 | Precor 9.35 Premium Series Treadmill
Precor safety switch does not stay engaged when in
Dear Sir:
Since this is the c.breaker.You must replace it.
The reason is mechanismo inside is broken, for that fact is faulty.
Proceed with the same model+amper+voltage: Please do not replace by other model with distint voltage+ amper+ model.
Disconnect the power cord before to replace, you must find in any radio schack, or computer, or hardware. sincerely G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA
Dec 03, 2011 | Exercise & Fitness
Where is the saftey switch on the precor 9.45i treadmill
You are refering to Reed switch or Sensor switch or Speed Sensor? please indicate.
Some equipment can have the safety switch when you remove the Hood as security measure, for to avoid the machine goes on or Start ON .
Please specify.
sincerely.
Nov 06, 2011 | Precor 9.21 Treadmill
We lost the safety key for precore 9.21i. will anything else work
You may be able to jerry rig something but it's much safer and always recommended to get a new safety key... saving $20 or less is not worth the risk. Here is one place to purchase a new safety key for the precor 9.21i. I like to recommend ordering two to have a spare and avoid paying for shipping again if you lose another one.
Aug 29, 2011 | Precor 9.21 Treadmill
I have lost the safety key to my Precor 9.20S. Is there a way to bypass and not use a key
I do not know if you can use it without a safety key... that is kinda the point of the key. I hope you can figure out a way but if it comes down to it there are many places online where you can find a replacement, here is one: http://www.fitnessrepairparts.com/cart/ViewItem/5000774
Sep 29, 2010 | Precor 9.21 Treadmill
Precor 9.1 won't turn on, outlet is good. (When unplugged, switch is OK & stays in on position. Once plugged in, switch flips off and won't stay on.) Site wouldn't allow me to choose correct model -...
I'm guessing the internal fuse is blown, which is part of the safety feature when you pull the magnetic key off. You need to put the little magnetic key onto the "stop" area after each use, and it will re-set. If you take the key off "start" and the machine stops, you can't start again until you put the key on "stop". Once you do that, the main switch should work again.
Aug 21, 2010 | Precor 9.21 Treadmill
Precor 9.21 Treadmill Logo
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
