Question about Abit NF7-S2G Motherboard
On/off leads disconnected
I recently got a abit nf7-s2g motherboard, but have no wiring diagram for on/off, reset switch and power/hdd lights
  • martinhibble Jan 23, 2009
    matt, did as you said and the onky thing that happened was the hdd light stayed on constantly. i was wondering if the power supply from my old winfast motherboard is not powerful enough to run my new one?
  • 63 Answers
If you have the Ports of the board facing you...
as you look down at it on the top right hand corner (ish) there is a black block with pins sticking out of it (some pins will be missing)
if you look next to that on the actual board it will have white writing saying [pwr] [hdled] [reset] etc...
thats where it tells you what cables go where
Let me know...
Matt
Posted on Jan 22, 2009
Reconnecting the pwr switch and HDD Led wires,etc
Hello here are the manual in pdf:
http://pclap.hu/driver_files/nf7_series.pdf
You will need adobe reader, to read content.
The front panel connector, look likes this:
Here are the abit homepage:
http://abit.ws/page/mi/download/download_driver.php@pFUN_KEY=9000&pTITLE_IMG=_2Fdownload_2Fimages_2Fdownload.html
Good luck
Sep 24, 2012 | Abit nForce2 NF7-S2 Motherboard
How to fix the power switch and reset switch pin in abit motherboard
Hmmm? Do u men how to install those connectors to ur mobo? Please read the manual instructions for ur mobo. Those small pins at the bottom corner is the place u have to connect those switches and LED lights. Hope that might help u out!
Nov 16, 2010 | Abit nForce2 NF7-S2 Motherboard
The computer fell over and the jumper came loose now I dont know where it goes
Starting from page 16, in the manual you can find the jumper configurations.
Regards,
Andras
Oct 04, 2010 | Abit NF7-S2G Motherboard
Driver for motherboard abit nf7 - s2g
Open the Abit NF7-S2G link provied below and download the drivers located to the right of the page listed under, Support Information.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF7-S2G&fMTYPE=Socket+A
Cheers'
Mike
Mar 03, 2010 | Abit NF7-S2G Motherboard
I have a ABIT-NF7-S2G. I am trying to format my computer however the usbs do not have power before the operating system starts so my keyboard does not work. How can i fix that?
hmmm. your System has an PS/2 slot for keyboard? you need to use ps/2 socket keyboard so that you can operate the bios set up and format your drive.. then if you finish put it back the USB keyboard.. ^^
Feb 03, 2009 | Computers & Internet
Connecting startup leads to ABIT NF7 motherboard
Below is a link to the manual for this motherboard, It should be able to show you where each of the leads on your dislocated panel wires go to.
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=6&category=5&subcategory=247&model=8&product_name=NF7
Hope this helps
Thanks
Dave
Nov 20, 2008 | Abit Computers & Internet
Abit NF7-S Nvidia2 Failed to Boot
Try swapping the power supply and as Nitro says also check the cable and connector from the power switch to the mainboard.
Jan 12, 2008 | Abit nForce2 NF7-S2 Motherboard
Power switch
You could try searching for the manual for the motherboard, I have the same problem every time I disconnect a motherboard.
Sometimes it is printed on the motherboard in dead small writing which wire goes where.
Also usually motherboard manufacturers follow the "unofficial" standard io connectors.
+PLED -PLED +PSW -PSW NC NC NC NC
+HDD -HDD -RST +RST +SPK NC NC -SPK
Key:
PLED = Power LED/Message LED
HDD = Hard Drive LED
RST = Reset Switch
PSW = Power Switch
SPK = Speaker
NC = Not connected (sometimes not even there)
Note quite often the Reset switch is the reverse of everything else! (i.e. on most if the + is on the right the + is on the left for the Reset
The USB ones usually always follow the following standard
VCC -DATA +DATA GND NC (USB1)
VCC -DATA +DATA GND NC (USB2)
And usually one of the NC pins is no pin as some USB cables have that pin blanked out to ensure you connect them the right way. Note also with USB you start with the VCC then you go straight to negative data, then positive, then ground (again the - and + data bits, like the reset are in reverse of normal reading - the are right to left, not left to right!)
Finally if your not sure which cable is + and which is - the - ones are normally either black or white (most of them are white, except the speaker ones which are black - I presume that goes back to the colour scheme of red and black for positive and negative in audio equipment) and the + ones are normally some colour.
Dec 11, 2007 | Abit nForce2 NF7-S2 Motherboard
Abit NF7-S2G Motherboard Logo
159 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
