I have a Samsung ns310 that won't charge. Purchased new charger but still won't work. I think it might have something to do with the dc jack port itself. Appears quite loose when inserted. Can this be fixed?
2 Suggested Answers
  • 72 Answers
SOURCE: DC power jack in Toshiba Satellite A65-S126 PC Notebook
Not that hard to fix if you are careful about taking it apart and re-assembling it. A digital camera is helpful during the dis-assembly to remind you later where everything went. Took me about 2 hours the first time I did one. Just take your time.
When your done, get a CRD (Cable Retention Device) to relieve the strain on the cable and the pin. I use one from this company.
Posted on Apr 25, 2008
Gateway nv52 won't charge
It sounds like you either have a dead mother board or a bad power inlet. Did the machine work with the new battery while it was charged? If so, then the battery connector was good and the inlet was bad. If not, your motherboard could be dead. I've also seen where a bad battery connector would syphon off enough power to not power on the machine or charge the battery.
Nov 14, 2012 | Gateway NV5215u Notebook
My laptop charging port is not working problem. I have to wiggle it about and selotape it into place for the computer to charge. What do you think is the most likely cause the port its self or the charger?
I think it is because of the loose dc jack. So
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place....
http://www.chargerbuy.com/laptop-ac-adapter/samsung-compatibility.html
Oct 29, 2012 | Samsung Rv511
Sony vaio not charging while charger plugged in
Seemingly your laptop dc jack is dead. How to confirm it? If you should wiggle your laptop charger on a position to let your laptop charge, it indicates your dc jack is loose. Either replace it or repair it. If your dc jack works well, please check your ac adapter. Maybe your charger is dead.
http://www.chargerbuy.com/laptop-ac-adapter/sony-ac-adapters.html
Oct 27, 2012 | Sony VAIO VGN-NS160D/W Notebook
My charger port is starting to not work
Obviously, your laptop dc jack is loose. You should repair it or replace it. If you are good at repairing computer, you can follow up the following instructions to do it by yourself:
http://www.chargerbuy.com/blog/dc-power-jack-repair-guide-do-it-yourself-instructions/
Oct 25, 2012 | Computers & Internet
Wont charge
The DC plug in the laptop is worn/charger plug, or the DC jack in the laptop is breaking away from the motherboard.
Mar 19, 2012 | ASUS Eee PC 1000 Notebook
My c500 presario won't charge and i think it's the charger. But when my battery went dead other times and i try to turn it on the lightning bolt indicator would always blink for a few secs. But now it just...
You probaly have a broken DC JACK on the motherboard. Therefore, regardless if you have a good power adapter. The power is not making a connetion to the battery because the DC JACK throught which the power flows is broken.
Try another adapter and remove the battery. If the computer is powered up using the new adapter then the old adapter is bad and the DC JACK is good. Replace the battery and if the batter charges, you can identify the old power adapter as the culprit. If the batter does not charge but the laptop powered on. Then both the battery and the charger is faulty-battery not holding charge.
Good luck
Sep 27, 2009 | HP Compaq Presario C500t Notebook
My battery doesnt hold a charge
That means that you will be needing a new battery. I would suggest that when you get a new battery (hopefully from the manufacturer) What you should do it charge it, and don't recharge it untill it has completely dead. That will help to preserve the battery longer.
All The Best,
Ryan Frame
Creative Energy Associates Technical Center
Jul 09, 2009 | Toshiba Satellite L45-S7423 Notebook
Samsung D900i
It is probably the charging port. It seems to be a common issue with this model of phone.
If it is the charger port on th eD900, You have 3 options.
1. get it repaired, under warranty if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay
For more information and links to the parts check the following link below.
Samsung SGH-D900 will not charge problem
Aug 29, 2008 | Samsung D900i Cell Phone
Samsung t509 won't charge
would something like this work?
http://www.bayho.com/p/PCMB-DC-KE850.html
Jan 09, 2008 | Samsung T509 Cellular Phone
Computers & Internet Logo
David Payne
David Payne
