Question about Car Audio & Video
6 channel power 1000watts earthquake amps red is on
Everytime i connect the output rca of the headunit to the input of the poweramp red light is on and green light on when there is no connection,
thanks, jowette
  • wett_reign Jan 23, 2009
    Hi, Fixya
    a very helpful web site, I'm impress , thank very much to Guru DAVE
    Cheers, Jowette
I have a earthquake d3 and the power light is on and the thermal light is on and all of sudden the system went out and came back on with the power light on with the car off. What could be the problem
Posted on Mar 28, 2010
    President:
  • 624 Answers
This is normally a grounding problem in the amplifer. If you have a volt meter, check the voltage at the ground of the RCA input on the amplifier. If that voltage is anything more than just a few millivolts then you have a problem in the pre-amp of the amplifier. You should also only connect or disconnect the RCA jacks while the system is off. Otherwise you can get a loud popping noise that can damage the amp or the speakers. Check that voltage on the amplifer RCA jacks with the head unit not connected to the amp with the RCA cables, then if that is OK, check the RCA cables coming from the head unit. You may even have a voltage on those RCA's coming from the head unit, in which case, you have a problem in the head unit. You will be looking for a DC voltage, if you have anything more than just a few millivolts (0.070 +/- DC volts) on either of those then you have found the cause. After that, it will require a technician to be able to troubleshoot the amp or the head unit to determain why you have that DC voltage where it should not be.
Let me know if I can be any more help,
Dave
Posted on Jan 23, 2009
How to connect a gs audio bc101 bass controller
Connect RCA's from headunit to INPUT leads, Connect OUTPUT leads to amp RCA's.
Jun 02, 2015 | Car Audio & Video
How to wire up outboard effects, poweramps to mixer. Out to sub, mains, monitors each with own poweramp, and several outboard effects, eq's, comp/lim/gate, sonic maximizer, quadraverb, crossover.
I'd need to know what mixer you have, to know if there is a [line out] connection socket and an [internal amp in] connection socket.
"each with own poweramp" I presume means the ep1500's and NOT that the speakers are active (ie containing amps)
***If any of your speakers are active, ask the question again, with more detail.***
So if all your speakers are passive, I offer the following.
I assume there is [effect send] and [effect return] on the mixer
effect send>quadraverb>effect return
mixer line out > eq > compressor > sonic maximizer > crossover
sub output of crossover> amp > sub
high output of crossover to mixer's internal amp input
mixer's speaker output > main speakers
monitor output > other side of eq (>other side of compressor if desired, but use sparingly ) > other side of sonic max if it is true stereo , otherwise skip > amp > monitors
If your mixer doesn't have an input to its internal amp, we are "back to the drawing board"
With questions like this it pays to give as much detail as possible; model and make of each component etc
I have done my best with the the info you have provided.
Don't feed amp outputs into powered speakers
Oct 18, 2017 | Behringer Europower Pmp5000 Powered Mixer...
Kenwood kac-749s amp power indicator flashing red. what does this mean and what can fix it?
Either there is a short in the in the amp or hopefully just the speakers or wires going to the amp. disconnect any speaker input output and turn your amp back on(you will only have power, ground, and remote wires plugged in at this time) and if the red protect light goes away, then there is a problem with the input/output speaker wires, this includes your RCA's. If it's still flashing red then there may be a stray wire shorting to the amp in the speaker outs, other than that your amp may be fried. By the way, if it works without any speakers connected, including RCA's try connecting one component speaker at a time starting with your RCA's(if using them), speaker in, then speaker outs. If it turns into protect mode, note which speaker/RCA it was and replace or repair the short.
Jul 11, 2011 | Kenwood Car Audio & Video
I have a turntable with a white and a red male RCA output cable. I am trying to hook it up to a Marathon DJ-1000 amp which has two TRS input channels - Channel 1 and Channel 2. Should I buy a twin female...
If I understand you correctly each channel has a single input in the amp, then yes! white goes into channel 1 and the red plug goes to channel 2 this way your signal will be stronger which translates into louder sound.
Jan 25, 2011 | RCA Audio Players & Recorders
I have a metra turbowire 70-1857 wiring harness, and i am lost at connecting it to my pioneer aftermarket DEH-1100MP. I have the harness hooked up to the amp in the trunk. and strung through car and in the...
well head units usually dont have just rca inputs....but the outputs can be changed to rca style with adapters. the speaker level outputs are what you need to change....good luck
Apr 25, 2010 | Metra Turbowire 70-1857
Cracky sound when I first on the headunit
try checkin your ground wire make sure its grounded on metal to metal no paint
Jan 22, 2009 | Generic Memory Clif Designs 4000W Digital...
Red light is on when i connect input cable earthquake 1000w amp
Cables are either shorted, or deck is putting out too much power for input on amp... many new head-units will put out up to 7v on the output jacks (RCA) the amp may only want to see up to 1v will need to consult head-unit manual for adjustment of outputs.
Jan 22, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
Help
I recommend you swap your left and right input cables to make sure it's not a source issue.
So from your headunit, plug the left channel output into your amps right input and your right channel output into your amps left input.
If the same side is still not working then disconnect both (or single speaker if it bridged) the speakers from the not working side at the amp. Connect the front and then the rear speakers individually and retest to see if one of them works.
If one does work then check the cabling and speaker connections on the one that doesn't. If it's shorting out anywhere it will stop your amp from powering that channel.
Failing that, it could just be that your amp has partly failed.
Feb 15, 2008 | Boss Riot 1500D Car Audio Amplifier
No output
Have you tried turning up the vol/gain control? Are all the switches on the amp set for full spectrum output? Are you sure you are using the RCA input and not the RCA output jacks (if it has such)? Check all the switches to be sure they are in the "most default" position. Something you might try, is to make a jumper wire to temporarily jump from the audio input ground to the power supply (chassis of car) ground. If this makes it work then you have a input ground problem in the amp. Good luck. P.S. As for epoxying the trace down on your other amp. If the foil is still in good condition then it should be ok to epoxy it down. If it needs some "help" then do that first, then epoxy.
Jan 21, 2007 | Hifonics BX1000D Car Audio Amplifier
Car Audio & Video Logo
199 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
