Question about Kenmore 15.5 in. Pedestal
Need part list for 12 inch Kenmore front load washer pedestal
Kenmore washer model#796.4031 pedestal pert list
SOURCE: Kenmore Front Load Washer Problem
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
Posted on Nov 02, 2007
  • 1028 Answers
SOURCE: kenmore pedestal for the front loading elite washer and dryer
some pedistals have a screw on drawer just behind front on end of rail newer ones have a small black lever on each side ..pull drawer completely out lever is about midway at end of inner rail pull lever 1 up other down drawer will pull off rail reinstall by sliding rails back together and pusing all the way in
Posted on Jun 11, 2008
SOURCE: Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Posted on Dec 30, 2008
  • 12 Answers
SOURCE: Installing pedestals for washer and dryer
its not but it is a 2 person job, the washer is in excess of 200 lbs and must be lifted onto the pedistal, after that its just a few brackets and philips screew to secure it.
Posted on Feb 07, 2009
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Posted on Mar 02, 2009
Will LAB2700LQo pedestal fit my Kenmore model 110-47532602 or 1108752601
Even though the Sears brand is made by Whirlpool, the 110 series is an exclusive line. IT is not likely to fit. You will have to measure the base and mounting holes on the pedestal and the machine.
Jun 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Can I use a frigidare pedestal model number apwd15w fit on a kenmore model number 41122
Good Morning Kristy, thank you for your question!
Because pedestals are designed specifically for the manufacturer brand appliances, I am unable to guarantee it is compatible for installation with a different brand as the dimensions and other specifications may vary.
Best regards!
Dec 02, 2013 | Frigidaire GLTF2940ES Front Load Washer
I have the Kenmore energy star front load washer, can't get the model number because I can't get the door open. How can I get the door to open after the wash cycle has finished?
most kenmore front loaders have either a door below the lock or, you can pull out the pedestal then: reach up inside where the lock is and, feel for a lever or, a ring pull the ring down or, the lever over, sorry I can't be more specific but, this info should help.
Jul 26, 2010 | Kenmore 43142 Front Load Washer
Kenmore Whasher shakes on spin cycle
unfortunetly this is common , these new frontloads spin fast even with no pedestal these things move...
make sure the locking nuts for the legs on the pedestal are screwed securely up to frame on pedestal, also could be a floor issue depending on where it is, slooping or not solid floor.
Jan 28, 2010 | Kenmore Elite 45986 Front Load Washer
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
Amana Front Load Washer moving during spincycle
what is the model # it may be for example, LAT9206BAE
May 08, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Frigidare Model # FTF2140FS1 problems with spin cycle
not a very sturdy pedestal, front loaders need concret solid base
Mar 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Replacement kenmore pedestal front drawer cover?
The pedestal should have it's own model number on it. Find the model number and contact Kenmore parts depot and they should be able to get you a front panel.
Dec 26, 2008 | Kenmore 15.5 in. Pedestal
I just wanted to know what pedastals will fit with the kenmore washer 48102
BEFORE U BUY PEDESTALS PLZ GIVE THEM MODEL NUMBER AND THEY WILL LET YOU KNOW WHAT WILL FIT THANK YOU
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
23 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
