Question about Kenmore Refrigerators
Kenmore refrigerator number 10664932400 freezing up
Model number 106.64932400
abhishek33
  • 1239 Answers
SOURCE: Kenmore Bottom Freezer Refrigerator
hi In some cases, a faulty thermostat may not be the cause of a warm refrigerator or freezer. A warm box may also be caused by a defective fan, a blocked fan, or broken or bent fan blades. If the blades are jammed, try to free them. If they're bent, straighten them with pliers. If this doesn't solve the problem, call a professional service person.
On some refrigerators, the door switch operates the evaporator fan. If the fan seems to be malfunctioning, the door switch could be faulty. Test the switch as detailed in the last page, and replace it if necessary.
Posted on Nov 06, 2008
rpbuice
  • 161 Answers
SOURCE: Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Posted on Jan 12, 2009
  • 306 Answers
SOURCE: Kenmore side by side refrigerator is not cooling or freezing
Sure sounds like a PTC relay bad. Take the relay off and shake it to see if you can hear a rattling sound.
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on Feb 04, 2009
Sea Breeze
  • 4654 Answers
SOURCE: fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Posted on Mar 29, 2009
  • 1891 Answers
SOURCE: i have a kenmore model number 106.53252202 that
look for ice build up in back of freezer . if so the defrost system has failed . heater / timer / ot defrost terminator . and of these could be at fault .. ck that fans are going and coils are clean .. **** ..
Posted on Jan 19, 2010
Kenmore coldspot refrigerator repair
20b285e5-2f39-4d20-a743-32f4ef00196e.jpgKenmore uses a model number like this example=> 321.2468901 and can be found around the fresh food section door frame. Let me know that number so I can look over the parts so I can help you solve this, Thanks Sea Breeze
May 09, 2013 | Kenmore Refrigerators
Water freezing in tube to icemaker
Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze
Kenmore Model Numbers
Apr 01, 2013 | Kenmore 26.5 cu. ft. Side-by-Side...
Kenmore 50522 refrigerator freezing everything
What is the model number listed in the refrigerator section?
Oct 15, 2012 | Kenmore 50522 / 50524 Side by Side...
Water tube to ice tray freezing up
Repairmantx is correct. Your dual water control valve is oozing water past the water valve that is used for the ice maker. Locate your model number and search for a dual water control valve if you have a water dispenser. Model numbers for Kenmore refrigerators looks like this example 325.326598. The first three numbers are the company that made your Kenmore refrigerator=> Kenmore - Who Made It for them?
I will be here should you have any questions, Thanks Sea Breeze
Feb 21, 2012 | Kenmore Side by Side Refrigerator
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Food in fridge is freezing.
I need your model number, you may have a problem with your thermistat. Sears uses a different model number system than everyone. The model number will look like this 231.0564879 for example. Or yours may have electronic vents. Let me know, Thanks, Sea Breeze
You may need to contact me because Fixya has a problem letting me know if you respond.
appliancepartsse@yahoo.com
Jul 20, 2009 | Kenmore 53082 / 53084 Side by Side...
Kenmore Elite fridg freezing everything
Faulty Thermostate, shouldn't cost much to replace. good Luck , the Yeti
May 20, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator Freezing
What is the make and model number of your refrigerator? Is it a frost free unit? How old is it?
May 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrigerator-Freezer top
install a defrost drain tube heater call sears for a part number have the model handy befor calling
Apr 21, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerators Logo
62 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
