Question about Frigidaire GLGF376 Gas Kitchen Range
FRIGIDAIRE GAS STOVE GLGF377ASE OVEN PROBLEM
I can smell the gas,no heat end after 20-30 seconds we have small explosion inside the oven.
  • Mark Egan May 11, 2010
    Please indicate whether you are using Propane/LP or Natural gas to fire this oven.
    Did the oven ever operate correctly, and if so, has anything changed about it's installation?
    You indicated small explosion, but sometimes you will hear a rumble as the main burner lights. If you can watch the sequence of the lighting process, then we will have a better idea of what is happening.
    You should see the following sequence -
    1) Turn oven on
    2) See the glow plug glow, then a pilot.
    3) After a period of time, say 30-60 seconds, you may hear the gas valve open, then within 5 seconds, the main burner light. If, at this point in the sequence, the burner delays lighting, look to see if the pilot has somehow moved away from the main burner (bent bracket, screw came out, etc.). This is where the type of gas is important, as well as whether this unit is orificed for that specific type of gas.
  • 61 Answers
I would replace the igniter and go ahead and replace the gas safty valve eather the ignitor is not allowing enought amps to open the gas valve enough to light or the valve is opening to slowly eather way i would go ahead and replace both this could be very dangerious is not repaired.
Posted on Jan 22, 2009
Frigidaire GLG=F366asd stove igniter problems and solutions . ... on the element lights up the smell of gas is real strong and then it lights and sounds like an explosion.
Where is the problem -- in the oven burner or a stovetop burner?
If something got spilled on a burner ring and clogged the small holes, especially near the igniter, the burner will be slow to light. A stiff wire (small enough to fit) can be used to clean out the holes.
Mar 18, 2012 | Kitchen Ranges
Gas oven stopped working
Sure i will be able to provide you solution
Apr 15, 2008 | Ovens
I have an ES340 gas self cleaning oven. I smell gas when I open the oven door. I checked all the connections in the back and the ones behind the back panel, and none are leaking. Are there connections...
Hello tds. It is not uncommon to smell gas when you open an oven door. That said, if the amount of gas you smell is stronger than it used to be call your gas company. They will send out a technician, free of charge, to check your stove. Joe
Thanks for choosing Fixya!
Jan 13, 2011 | Frigidaire Ovens
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
I have a Frigidaire stove, when I turn the oven on the element lights up the smell of gas is real strong and then it lights and sounds like an explosion.
Have you spilt anything on the burner? If so it will need to be cleaned,you will need to do the following (you need a pin, a matchstick, a drinking straw and a torch):
Make sure the oven control and the electric isolated is off please, remove the shelves, using the torch, inspect the oven burner, if there is no apparent blockage, disregard the following advice and seek the help of a 'Gas Safe' engineer in your area.
If it is blocked,using a pin or matchstick clean the holes in the burner, and use the drinking straw to blow the debris away. Move away from the burner, and see if it lights.
If this fails to work it could mean that the ignition is in the incorret position allowing for explosive ignition. See advice from a 'Gas Safe' qualified engineer.
I hope this helps.
Jul 06, 2009 | Frigidaire FGB24T3A Gas Single Oven
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
Oven won't light on low settings (170), no trace gas smell.
Igniting bar located on the inside of the oven it is a rectangular piece with one or two screws. It is basically a heating element that also controls the gas. Change that ignitor and it should fix it no problem.
May 03, 2009 | Frigidaire FGF326AS Gas Kitchen Range
GAS STOVE - MODEL GLGF377 - FRIGIDAIRE - OVEN SMALL EXPLOSION
find the broken part and replace it. it really is that simple!!!!
now seriously, you need to explain what is wrong.
let us know what kind of problem you are having... ie. the oven glow bar glows but doesnt let gas in to heat.
if this is your problem then replace the glow-bar ignitor and that should fix it.
give us more info and we can help you out.
Jan 22, 2009 | Frigidaire GLGF376 Gas Kitchen Range
Oven gas
For safety purposes call gas technician to check your gas pipe. If stove turn off supposed not to smell gas.
Jul 23, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire GLGF376 Gas Kitchen Range Logo
272 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
