Question about Hitachi 43UWX10B 43" Rear Projection Television
Tv sound works sometime and not other times
Our tv is 6 years old about three months ago we notice a crackling and then the sound would work when you first turned the tv on. Then it cuts out completely. If you leave the tv on for hours then turn the tv off for 5 minutes then turn it on again it works fine. However this is annoying to say the least.
    Scholar:
  • 150 Answers
On some of these Hitachis they have a surround sound option, there is an additional board in there that goes bad and needs to be repaired. suggest a repairman or service center.
Posted on Jul 07, 2007
SOURCE:
HELLO I BOUGHT A 60 INCH SAMSUNG SMART TV ESUN8000, 6 MONTHS AGO, AND I NOTICE THAT IT HAS 3 WHITE DOTS. WHAT CAN BE THE CAUSE OF THE PROBLEM? I BOUGHT THE TV AT BEST BUY, DO YOU THINK THAT THEY CAN H
sound like you have samsungs dlp white spots plague, which just gets worst. samsung are aware of the problem, so you need to get in touch under the warranty.
Nov 25, 2013 | Sony KDF-42WE655 Television
Westinghouse TV making crackling sound
I have had the same issue with a Westinghouse 50 inch LED TV. I believe it is not the power supply but the HDMI input. You can temporarily work around by plugging your primary source into the other HDMI. You may also get some relief by using the Westy remote, finding the TV menu, then selecting (Option) (Restore All). There may be an arcane procedure to reset the HDMI.
Jan 01, 2013 | Westinghouse Televison & Video
Tv is on with no picture or sound, only 4 months old!!
Hello
The power supply regulator board to your set has the fault. If you try to open the set, or try to repair it by yourself, the warranty will void. The set must have warranty as it is new. Why do you spend for it? Just contact the nearest authorised service center for Sceptre. the components in this set will be very hard to get from open electronic spare part market, and will costly too.
Mar 11, 2012 | Sceptre 32 X320BVHD 32 LCD TV
Comes on and off every minute or so. I have replaced the bulb three months ago with "Electrified XL-2100 / A1606034B", and it worked fine so far. Now I am seeing the above said symptoms (comes...
hello my is rico i work on tvs sometimes, it looks like you have bad lamp or your cooling system is work properly maybe thermal sersor. if need help fixing your tv let me know feel free to call me at 602-810-7149 anytime.
Dec 29, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
37"RCA Lcd TV quit working
no parts available google model for part # for main pcb
Jun 08, 2009 | RCA L37WD12 37 in. LCD HDTV
IBM 21" frequent tick sound!
too much refresh rate! set it to 60 hz only! you're over-stressing major components on your monitor!
Dec 02, 2007 | IBM P 202 21" CRT Monitor
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
Hitachi 43UWX10B 43" Rear Projection Television Logo
129 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
