Question about Dell E173FPc 17" TFT LCD Flat Panel Monitor
Dell E173FPc 17" TFT when turned on goes black
Hi i have a Dell E173FPc 17" TFT LCD Flat Panel Monitor and when its turned on the screen comes on and the says auto adjusting then goes black cheers for any help
  • andygressett Apr 02, 2009
    I have the same problem. I unplugged the monitor and disconnected it from the computer. I powered the monitor directly from the wall socket. The STFC appears for about one second and the monitor goes black. Turn off the power and then turn the power back on and the smae results occur; i.e., the STFC appears for about one second and the screen goes black.
    Solution?
  • Anonymous Mar 14, 2014
    Dell E176pf 17in Flat Panel LCD Monitor
    Scholar:
  • 135 Answers
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Posted on Feb 24, 2009
  • Farrukh Shahzad
    Farrukh Shahzad Jul 08, 2012
    I see STFC for a second and then black screen
Will my dell tft show anything on screen if no input
Normally you can push the menu button on the monitor to look at menu options. If there is no input it will normally show that on the screen initially and they go into sleep mode.
Nov 06, 2013 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell e173fpc Display Issue
Check if the cable connected to your monitor and video card is fix and secure.. Check also if the video card is properly seated in the motherboard.... Try to check using other computer if the video card is working..
If the test is all ok.. then the last option will be to check the backlight inverter of your monitor....To do this, you need to bring the monitor to a credible technician to have it replace..
much appreciated if you could rate this help..thanks..
May 24, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
My dell E173FPC monitor screen is black and doesnot show for more than 2 seconds although the green power button is on.
You have a unit with a failure in the backlight power supply. This is a common problem with LCD monitors after 2-3 years of use. Here is a link to an article we have posted that shows what needs to be done to repair the unit along with full parts list: http://www.ccl-la.com/blog/index.php/dell-e172fpc-e173fpc-repair/ If you can solder then you can do the repair yourself. If you don't care to do the repair we do offer a repair service for the unit, details can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 29, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
No power to Dell E173FPc monitor; power light doesn't come on
It sounds like you are not getting any power. I would try another power cord to see if it makes a difference.
Jun 16, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Monitor goes blank after a second after power outage
what happend is your monitor cought the brown out and the power supply capcitors are not defective and what that means is the monitor needs to be repaired there is no quick fix please rate accordenly thanks.
Apr 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc monitor. Screen is black, power button color cycles
Turn on the monitor
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc
VGA turns on after a few seconds turns off
Jun 29, 2008 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc 17" TFT LCD Flat Panel Monitor Logo
782 people viewed this question
Alun Cox
