Question about Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat
Very Hot water coming out of overflow pipe
6 year old Heatline boiler. water out of overflow and backing up to boiler.Pressure guage up and down.Hot water in house only lukewarm.
Heating on but not very hot, and when on pilot goes on and off.
Air pockets in radiators, but when bled, only water, not air comes out.
Have been told it could be thermistor or a stat problem.Any ideas?
Siobhan.
    Scholar:
    New Friend:
  • 70 Answers
Is your boiler heating your domestic hot water if so i would turn water off to water maker and see if your boiler pressure stays down below 20 psi. If so water maker is bad. The other thing that could cause this problem would be the boiler pump is out.
Posted on Jan 23, 2009
Ideal mini c28 too much pressure
Check filling loop to see if it is closed and not letting by, may need to be replaced.
Oct 14, 2015 | Water Water Heaters
Wickes 102 combi boiler constantly loosing water pressure
It sounds like your thermostat could be the problem. Have you noticed the boiler cutting off at all, or does it run continuously until it goes out on low water?
You stated, "when boiler is on", so I am wondering how you get the boiler on. If your boiler is controlled by a thermostat, you need to check it for a cold draft possibly from behind the thermostat in the wall where the wires come through. The thermostat should never be on an outside wall. The thermostat could be defective.
An aquastat can also control your boiler. If you have an aquastat, check the setting, typically 175 - 180 degrees. You should also have a "high limit" which should be set at 210 - 220. Some people run that high side limit higher; not a good idea - defeats the purpose. If the aquastat is set too high, the boiler will operate too hot and the problem you have will occur.
"pressure rises and pressure relief valve opens" This could mean that your pressure switch is prematurely venting. Check boiler temperature to see exactly at what temperature the T&P valve purges. If it blows off below the high side setting, either adjust or replace. The T&P valves are usually not adjustable. That blow off temperature is stamped on the head of the valve. So, if it discharges too soon, replace it.
Have you actually seen evidence thgat the T&P valve is opening? You may have a bad bladder in your expansion tank and your system may have air in it. Your boiler should have 12 psi when cold and 20 - 22 psi when operating. Check your boiler pressure guage.
this eventually drops below the minimum operating pressure" Technically, there is set point for a NO MINIMUM OPERATING PRESSURE. That is a function of the amount of water in the boiler. If the T&P is blowing off, it will vent water from the boiler and the boiler pressure will go down. There is a minimum operating TEMPERATURE.
Your boiler could be low on water. You will have to manually fill the boiler. Be careful of thermal shock to the boiler. Feel the piping, and fill only when the circulator is running. Make sure the water is not going directly into the boiler. The supply water should go into the circulating supply side which feeds the radiators, radiant floor, or base board circuits.
All this will adversely affect your hot water. The heat exchanger for the potable hot water may have scale build up in it. Using the hot water keeps the boiler running, and a scaled heat exchanger will give you cooler hot water and the boiler keeps running. If this is a problem, you will need to replace the heat exchanger. A better idea is to not use the boiler for your domestic hot water. Why run the boiler in the summer?
Feb 02, 2013 | Water Heaters
Boiler losing pressure and overflow pipe dripping water
replace that leaking safety valve first
May 12, 2017 | Water Heaters
Worcester 350 boiler pressure low - warning light comes on so i top it up with water half an hour later the pressure drops again. Have checked rads and pipes no obvious leaks. Water seems to be coming out...
That overflow is the Pressure Relief Valve.usually they are set at 3-3.5 bar but over time they can be gunged up inside and leak/allow water to flow out. Dismantle & clean or replace. Turn off mains water and ch pipes before removing - operate valve remove & allow for some water to leak from it
Oct 15, 2009 | Water Heaters
Hi. my heatline vizo 24 boiler not working
overheat stat or fan best of luck
Oct 13, 2009 | Water Heaters
Heating pressure gauge goes up
yes tami
there should be a pressure rellief valve fitted.
it also sounds like the heat exchanger is blocked if the hot water is not as good as it used to be and the boiler reaches temperature too quickly then there is scale in the heat exchanger and needs to be cleaned or replaced
Mar 27, 2009 | Water Heaters
Hot water
there are two main faults with combi boilers not giving hot water. one is a faulty flow sensor, the other is the most common which is a blocked heat exchanger caused by debris and scale in the system. this needs to be flushed out or may require a new heat exchanger depending on the age and condition of the boiler some plumbers may suggest a new boiler.
Mar 02, 2009 | Water Heaters
Combi Boiler - Hot water pressure low
the coil inside got clogged
Dec 22, 2008 | Water Heaters
Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat Logo
865 people viewed this question
Top Protech Systems Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Protech Systems Water Heater Expert? Answer questions, earn points and help others
