Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
MAYTAG STACKABLE WASHER/DRYER FABRIC SOFTENER DISPENSER
I WOULD LIKE TO KNOW HOW MUCH SOFTENER I USE AND IF I NEED TO DELUTE IT. I HAVE FILLED IT UP AND IT SEEMS THAT IT IS TOO MUCH SOFTENER FOR THE LOAD OF CLOTHES. I CAN NOT FIND MY MANUAL SO WONDER IF I NEED TO PUT 1/2 AND 1/2 SOFTENER AND WATER IN THE DISPENSER. THANKS FOR YOUR HELP.
I read in my manual that i should dilute the fabric softener with water. This is so that it won't cause any clogging. which happened to mine. I had take off the dispenser in the middle and rinse and repeat with hot water to get all the gunk out.
Posted on Jan 22, 2009
  • 61 Answers
Check the lable on the softnef bottle it should tell you how much to use and how to delute it .
I have a Neptune stack washer that leaks water out the door on the 3rd rinse cycle on the side where you put in the fabric softener. When the wash is done and I open the door the fabric softener...
Hi, thanks for using FixYa.com. I suspect the dispenser may be plugged up a bit or the hose from the dispenser is plugged. Remove the dispenser insert and clean out the tray with hot water. After that, open door and remove the 4 phillips screws, 2 on each side of the door opening. Once removed, pry the front panel away the machine and set aside. Find the rubber hose coming from the dispenser assembly to the tub ring and remove it. Clean the hose and the inlet on tub ring of softener build up, reassemble and enjoy a properly working, non leaking washer!
Sep 16, 2010 | Maytag Washing Machines
My stacked Maytag front loader leaks out through the door when the fabric softener dispenser is being filled (2nd rinse cycle only). Any help?
The second rinse is when the softener cup is being flushed. Remove the dispenser and clean and inspect the housing to be sure no softener is gumming up the holes and blocking the water flow into the machine.
Jun 11, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
Water colects in lid sometime during the cycle.Drains onto washed clothes when lifting the lid to remove clothes. Water seems to be combined with fabric softener. Bleach holder also is filled with water....
I had the exact same problem. The problem is that your fabric softener dispenser is clogged up with a lot of dried, sticky fabric softener. The flooding comes from the part of the cycle when water that is to be flushed through the fabric softener dispenser can't drain properly so it spills into the bleach dispenser and onto the top and into the lid gasket as well.
To remove the dispenser for cleaning, you need to open the top of the washer. (First pull it away from the wall.) Carefully pry off the little emblem in the front center of the washer lid. Then remove the screw. Then slide the top forward to you about a 1/2 inch and prop it up carefully.
You then need to remove both hoses that are attached to the bleach and fabric softener dispenser (part of the same unit). Then unsnap the combined unit from the washer top. Then clean all the gunk out by running it under scalding hot water in the laundry tub and swirling the gunk out. Don't attampt to remove the blue round fabric dispenser part from the unit.
Put it all back together and you're good until you clog it up again with too much fabric softener; maybe several years again.
Good luck.
JRR
Mar 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Stackable softener dispenser stays filled with
if its the dispensor on top of the adjitator it snaps off then you can unscrew some of them to clean. or just soak it in hot water.good luck!
Jan 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
I went to Sears today and asked!  They said use high efficiency detergent (marked HE on the label) and put it directly in the washer with the clothes.  Mystery solved!
Jul 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Detergent dispenser tray will not open
we have been having the same issue - it's possibly the fabric softener blue 'cover' that becomes raised to hit the top of the dispenser unit
we took the top cover off the washer & my husband lifted the dispenser unit lid (as much as possible) and I was able to pull out the dispenser tray
we just removed the cover for the fabric softener so it won't happen again!!!
Jul 25, 2008 | LG WM2277HBW XL Front Load Stackable...
Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Feb 11, 2008 | Maytag Neptune MAH6700A Front Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
118 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
