Question about Zanussi FJS1225W Front Load Washer
Down load user manual zwh7142j
1400spin cycle 7kg wash
How can I get a shorter wash on the Logixx7. Every wash is lasting at least 3hrs!!!!!!!!.
Hi dear,
I do not know what type or model of your washer but those LOGIXX series should have a INTENSIVE wash button. Make sure that button not active when you setting your program by default and you are not over loading your machine. You need to use specific program for specific wash load. Example: Let's say your machine has 7Kg dry weight wash capacity. That's indication for Cotton Fabric Only. Your machine able to wash 7Kg Cotton fabric but it can not able to wash 7Kg WOOL, Dedicates, Jeans etc. Refer your machine's user manual. I hope that helps. Thanks.
Jan 31, 2016 | Bosch Washing Machines
I need a user manual for my 7kg EZIloader front loading Simpson washing machine
Google the make and model and add the words user manual to the end. There you will see numerous sites that offer either free or inexpensive user manuals that you can order or download. My favorite site is simply manuals.com.
Sep 04, 2011 | Washing Machines
I have just acquired a LG Incello Washing maching (7kg) WD80130C and I haven't been given a manual. Can you please send me one?
GO TO WWW.LG.COM/AU. CLICK PRODUCT SUPPORT LEFT HAND SIDE OF SCREEN.TYPE IN MODEL NUMBER WD-80130C . UNDER NEATH SEARCH BOX IN RED SHOULD COME UP WD-80130C WASHING MACHINE CLICK ON THIS. HALF WAY DOWN PAGE DOWN LOAD PDF FILE ENGLISH .
Feb 22, 2011 | LG Washing Machines
Lg wd80160fu front loading 7kg washing machine when power is on shows (cl) on its screen.
cl is child lock......look for your units user manual and reset the child lock....usually its one button to push and hold in.....but some lg's have two buttons......just look at your user manual and reset......
a feed back would be good if this helps
thanks
May 16, 2010 | Washing Machines
My lg 7KG 1405F model in does not complete the washing cycle stops at rising (oe) is the code
OE is drain error, which means that the machine has detected that the water level is not lowering quickly enough...Probable cause is a blocked pump filter...Check via small door at floor level..Unscrew pump cover and clear filter....Remember that all water will drain from this point, so drain machine first...Leaning the machine back can help...Good luck....Nomess
May 20, 2010 | LG WM-1480FHD Front Load Washer
My zanussi jetsystem washer/dryer 1400 7kg load machine is not draining or spinning. It is unlocking so I can (at the moment anyway) get the load out, but the clothes have not drained or spun, therefore...
your machine require new set of carbon brushes, and it also may need the pump impeler checked to make sure there is nothing stuck in it such as hair pin safety pin or a wire from the under wired bra.....
Dec 04, 2009 | Zanussi ZWF1440 Front Load Washer
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
The 7kg hoover will wash then stop agitating
There can be many reasons why the machine does not agitate. If it does not complete the cycle, then it can be a problem with the timer control, see The cycle doesn't advance .
If cycle goes on, but does not agitate, it can be the agitator and more, see It doesn't agitate or There's no delicate or regular spin or agitate
Oct 08, 2008 | Hoover HTC243 Top Load Washer
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
29 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
