Question about Sony DVP-NS57P
Sound output reduced
My DVD player was fine until one day the volume output drastically reduced.  The TV is fine and its volume is functioning okay.  The player used to work okay till now.  The images are coming on fine but the volume has dropped.  I have to keep the TV volume to the max to make out what's going on on the DVD player.
    Scholar:
  • 145 Answers
There is a volume control on the Remote of your DVD player , increase the volume in that and it should solve. Additionally check the audio output cord of DVD player if it is intact and tightly fitted.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Posted on Jan 22, 2009
TV audio output vastly different for satellite feed versus DVD feed. Why?
It is possible there are separate sound level functions for the DVD player, the tv and the satellite box, try the different remotes for each by unlocking the volume control on the satellite remote until you get them close or use the device specific remote volume controls. I would also try and use HDMI if available for the DVD instead of composite. If the volume controls are different it will show on the tv, might also go through all audio settings for each device. Some devices are pre-amped or send out strong sound signals while others are line level outputs designed to be amped by the output device, in this case your tv I believe. The HDMI vs stereo audio that goes with composite may be the cause or it could be in the settings of the device. Worst case is to remember to drop volume before you switch back so you don't ruin speakers.
Jan 25, 2015 | Televison & Video
Tip
How to set up a home theatre system ?
Considering a home theatre system, you will have to connect both the audio and the video cables of your home theatre system to your DVD player, so let us first start with the connection of the audio cable.
Step 1:Firstly you must find the digital output point on the back of your DVD player. It will be labelled as "COAXIAL" or "OPTICAL". Some of the DVD players may have both the Coaxial and the Optical output. In that case you must connect only either of them. Both the outputs require different kind of output cable. The Coaxial output uses a standard shielded RCA cable which is plugs in an RCA jack which is labeled "COAXIAL DIGITAL". The Optical output uses a fiber-optic cable which has a square shaped connector at both the ends. Both the outputs deliver almost the same quality of sound but the Optical cable sometimes allows us to prevent ground loops. Both these digital cables do not carry any video signals. Now connect either of these to the digital audio input which is at the rear of your reciever.
Step 2:Now you must connect the video cables. Before you start doing that you must decide if you want to connect the video cables through the A/V reciever and then connect it to the TV or just directly connect it to the TV. By connecting the wires to the A/V reciever and then to the TV usind two separate cables has its advantages in which you find convenience if you want to switch the reciever to watch a DVD and also you will be able to see the on-screen menu on your TV. By directly connecting the cable to the TV you will find it easier but again you would not be able to see the on-screen menu.
Most of the DVD players will have three video outputs. Connect all three of them inorder to recieve maximum video clarity from a DVD. It is necessary to have component outputs on your TV and/or your AM reciever inorder to connect all the three video outputs. In case you dont have an component output then you will have to connect only one s-video cable to your TV input. This s-video cable is a single cable with a multi pin plug. In case there is an component output for your TV. then you will require three cables(RCA) which have different colour codes(which are sometimes binded togethr). the colours are usualy Red , Green and White. Using the component output gives you the best video quality next to which is using the s-video output. The DVD player may also have an HDMI or DVI connectors. These help in maintaining the video in its digital form rather than converting it to anolog form.
Step 3: Make sure you dont turn the volume of your surround sound too high in which case any one of the speakers might call attention to themselves. In other words, in case the volume of the surround sound is too high then sometimes one of the speakers on your rear may call your attention separately. Hence it is recomended to keep the volume in its optimum level. Many of you might even wonder if the surround system is actually functioning properly until you experiance an of-screen sound such as a phone ringing at the backround or the sound o thunder in case of a rainstorm . Hence you must know that a surround system is not for loud noises and rather to experiance a three dimensional environment in between a movie.
There are certain things which you can do inorder to experiance a better feel using your surround sound system. Few of them are as follows,
1. It is advisable to get a test DVD which will help you adjust the surround sound levels and make maximum use of the system. For instance get a Sound and Vision magazine home theatre tune up DVD. IT will help you in maximizing the effects of the system.
2. Always remember to keep the central channel speakers setting at low. In case the setting is high then there is a loss of clarity of speech.
3. Try changing the seating arangements around the surround speaker system. Sometimes you might feel better audio quality at certain positions.
4. Always keep the brightness of the TV on optimum range. This is better for viewing more particular details in the picture quality as well as increases the life of the TV. Hence high brightness will reduce the life of the TV as well as give u less details on the picture being viewed.
5. Always have the volume of the sub-woofer at medium when you play music and then gradually increase it to how much ever necessary.
on Sep 12, 2010 | Audio Players & Recorders
Denon avr-587
Make sure that the volume is not muted or too low on the TV...the TV volume output to your receiver will be performing the function of a pre-amp to your receiver. Then select the appropriate input on the receiver that you have the TV audio connected to.
Jul 17, 2010 | Denon AVR-587
Goldstar dvd m#dv4721nc works fine but sound
put in closet for a rainy day not worth getting plan until i have a few problems with other components
Jan 05, 2010 | Goldstar DV7411N DVD Player
My older Yamaha receiver has lost volume on the TV output.
if TV outputs are okay.Then simply connect TV into another input on reciver, AUX,TAPE,VIDEO ETC...if problem persist then output from tv is the problem..check settings on tv
Jul 29, 2009 | Yamaha RX-V2400 Receiver
Connecting a toshiba sd-v392 to an old analog tv
Make sure your menu settings are correct audio outputs may have a setting for digital or analog sound output check that these are set up to analog or stereo output .Also try hooking the sound up direct to a stereo system or amp to be sure you have output! Also you may not be able to get your sound thru the convertor box!! Because the convertor is a reciever of digital signals not a line amp. for audio !! Hope this helps11 AAAAAAAAAAAAAE!!!! Swampratt200 ! Out!!
Jul 21, 2009 | Toshiba SD-V392 DVD Player/VCR
Vizio 22 inch HDTV--Loss of volume on non-HD channels only
Good evening! Go into your audio section of the Menu and make sure that SAP is off.....let me know how you did.
Apr 21, 2009 | Televison & Video
Bush DVD2038 No Sound
if tv has RCA(red & white) inputs,and dvd has RCA outputs,try using an rca lead for the audio.if it dont work,bin it.
Jan 08, 2009 | Bush DVD2038 DVD Player
Dvd sound isn't working
In addition to the suggestion which I fully concur with, there is one small thing I would add. Kari you may not be aware that there is often an "internal setting" in the dvd player for its output volume. Sometimes the setting is inadvertently changed to a permanently "muted" or silent mode so that no audio can be heard. This internal setting is usually accessed by pressing the "Setup" button on your remote control and browsing through the main menus to the "Audio" or "Sound Setting" submenu. Once there you will see if the settings are correct in order to HEAR AUDIO (sound that is). Be sure to turn the "MUTE" to "off" and set the output volume to about 3/4 high setting. Then get out of setup mode and play your dvd. My point is this...on some "kareoke" feature units I have found many people mistake the front manual volume control for a DVD audio output level control when playing dvd's. This is not the case..the output volume settings are "internal" and accessible through the remote control only. Hope this helps Kari !- hattonhall
Sep 08, 2007 | RCA DRC8300N DVD Recorder/VCR
Sony DVP-NS57P Logo
178 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
