Question about Ott Light OttLite Truecolor Table Lamp
My ott light makes a buzzing noise for an hour or more, but eventually stops,. any ideas of cause
I have a kitchen aid over the range microwave that makes a humming noise ehen off. Almost sounds like a buzzing transformer. ykhms1850ss-0 Is the model.
Possibly the wall receptacle has been wired with black and white wires reversed and/or the green ground wire not connected.
I had a GE microwave that periodically would buzz white operating but eventually the buzzing stopped.
Sep 16, 2016 | Microwave Ovens
Duke 59-E3XX Contactors buzzing when starting?
Contactors are getting weak and need to be replaced.............the buzzing is the magnetic coil making noise. Anytime I hear a contactor buzzing on a furnace, ac, or refrigeration rack I replace them immediately. Otherwise what happens is eventually it will get stuck closed (on position) and cause a issue later.
Aug 23, 2013 | Duke 59-E3X Electric Single Oven
Danfoss 103 timer is making a constant buzzing noise!!...everything's works fine but I want to stop this buzzing noise. Any actions I should take or advice would be much appreciated. Thanks.
How much wattage is going through the timer and what is its rated load max? try unplugging whatever is plugged into it and see if it stops but if you exceeded the max load might be damage to the internals which can cause that buzz.
Feb 05, 2013 | Hardware & Accessories
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung HL-P4663W/HL is making a buzzing noise
Color wheel needs replacement is the most likeliest cause.
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a Samsung rear projection tv. It has been
The Lamp probably is bad but it going bad would not cause a buzzing sound. I have a hunch that the Color Wheel Motor is bad causing the buzzing noise. It is a major repair and the cost would be expensive. But this is the deal, you will need to get a qualified repair person out to confirm the symptom to be sure. You can go ahead and replace the Lamp to get the set working again and use it for as long as you can stand the buzzing noise. If it is the Color Wheel Motor, I would check prices on replacement sets just to get a feel of how much you are willing to spend for repairs.
I hope this helps,
Skyassoc
Oct 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Buzzing sound in Acer Aspire 5535
I've come across this before and it turned out to be the soundcard driver. See if there's an updated driver on Acer's website.
Strange buzzing can also be caused by a stuck or damaged key. Does pressing ESC help at all?
Unlikely to be the hard drive. They crunch and grind but don't buzz, unless they're completely knackered, when they can give you a three-tone buzz sound and won't spin up at all.
Hope that helps,
Matt
Aug 24, 2009 | Acer Aspire 5535-5050 Notebook
Wii makes a horrible noise while loading or ejecting the disc
Hello my name is Tim Ehrhart, I repair 360's and have had this problem with them and there problem is that the magnet that holds the disk in place gets stuck and makes a grinding noise that sounds horrid. Please leave feedback as I am new and trying to build a great rep. Thank You.
Mar 12, 2009 | Nintendo Wii Console
Buzzing noise
check under vehicle on frame rail drivers side, should see abs assembly, disconnect red wire buzzing will stop, will have to replace assembly, will not have abs braking, will have base brakes, if red brake light comes on do not drive vehicle, have towed to repair shop
Nov 24, 2008 | 2000 GMC Yukon XL
Ott Light OttLite Truecolor Table Lamp Logo
292 people viewed this question
Top Ott Light Home Experts
Donni Steen
Tom Chichester
Are you an Ott Light Home Expert? Answer questions, earn points and help others
