1. Right side not printing. Rotate round green knob (possible black center) found on right side of printhead assembly clockwise (or if necessary, through entire range) printing at each stop to check, until printing is satisfactory. If not fixed, next step is to do "Burnline Adjustment" as described in Operator's Manual. 2. Left side not printing. Make sure that large green plastic printhead latch on right is pushed firmly toward back of printer while printhead is pressed down, to make positive lockdown of printhead. Try rotating round green knob described in (1) above through entire range, printing at each stop to check. If not fixed, next step is to do "Burnline Adjustment" as described in Operator's Manual.
Welcome to FixYa. The Zerba Driver might have been corrupted. Uninstall the Zebra Driver/Software from the Control Panel.Re-install the Zebra driver using the Disc that came along with the printer. Thank you for using FixYa.Have a great day.
Some CD label software allow you to adjust the "overprint" by resizing the image you are printing. If your software doesn't allow you to size your image larger than the label (so it overlaps) try a different program. Look for a setting that allows it to over print. It's not an exact science...you just have to try to make the adjustments you need. There are also different CD/DVD label sheet types where the labels are setup on the sheet differently. maybe a different setup may work better. However, usually Avery is pretty good.
Check the drivers you are using, try downloading drivers from Nice Label or Segull Scientific. Setup the page size to fit all the text, use a ruler to measure the lables.
Printing Directly onto a CD or DVD in Roxio Express Labeler
Make sure that the product is turned on and that the USB cable is connected to the product and the computer.
Click
Start
, click
All Programs
, click
Roxio
, and then click
Roxio Express Labeler v3
Click
Disk Label
, then click
Options
Figure 1: Options1 - Options button
The Options screen appears.
Figure 2: Options screen
Make sure that
LightScribe 12cm Disc
is selected from the
Disc Label
menu, then click
OK
to return to the Roxio Express Labeler window.
Click
Disc Titles
, type the title and subtitle for the CD or DVD, and then click
OK
Figure 3: Disc Title option1 - Disc Titles buttonFigure 4: Edit Disc Title screen
Click
Background
, then click
Import Background
to use an image on the computer as the background on the CD or DVD. Click
OK
Figure 5: Background option1 - Background button
Insert
a LightScribe CD or DVD into the LightScribe drive of the product. Make
sure that the label side of the disc is facing down.
In the Roxio Express Labeler window, click
Print
. The LightScribe label is printed on the CD or DVD.
Figure 6: Print1 - Print button
your printer does not support CD label orinting. though you can still print CD labels but with some softwares. there are HP printers that prints CD labels. Check them out.
HP Lightscribe Use LightScribe technology to label CDs and DVDs.
HP Photosmart D5460, D5463, D5468, and D7560 Printers - Printing Directly onto a Printable CD or DVD in HP Solution Center ... On a computer running Windows, print directly onto a CD or DVD using the HP Solution Center software.
HP Photosmart Premium C309a, C309c, C309g, and C309n All-in-One Printers - Printing Directly onto a CD or DVD - c01622666 Review steps for printing directly to a CD or DVD.
HP Deskjet 900C series printers - CD Label.
These printers comes with a special software that enables them print on CD labels. Also try to get their softwares and see if you can interface them with your own printer and them print. Else you may have to get one of these printers that support CD labelling. Cheers!
If you are using windows go to Start, Printers and Faxes. Right click on your printer and select Printer Preferences. Under the Advanced tab there should be an area where you can change the dimensions. You'll want to change the Width and Height to match the dimensions of the label that you are using. These are usually in inches or inches/100. Ex: 1 inch = 100 in/100.
First click "Print" in there you will see "Adjust print position", adjust to 0.1mm up and 0.1mm left this should center. Depending on the label you're using you will have to keep adjusting until you get the right result.
Verify your LCD Display Print Width setting is set wider than your actual label width. The printer will only print to the width of the PRINT WIDTH setting. Also verify any driver or software settings as these override your printer settings.
