I get a blank screen, and it says out of range.
  • Jay
    Jay May 11, 2010
    Is your monitor displaying the Out of Range error after bootup or before you even turn on the PC?
  • 85 Answers
Clean ur RAM and insert it again it will solve ur problem
Posted on Jan 23, 2009
Computer 1 out of range
The resolution on the computer is not supported by the projector. Go to your Display settings and adjust your screen resolution.
Start > Control Panel > Display Settings
Nov 25, 2011 | NEC LT380 LCD Projector
LG Range LRE30453ST quit working. Breaker in panel shows appropriate voltage rating, range receptacle shows appropriate voltage rating, and power cord connection shows appropriate voltage rating. The...
I can tell you aren't familar with house wiring. So we will start from the beginning. Circuit breakers are rated by the AMPERAGE that it can handle. When there is a current surge above the rated AMPERAGE the breaker is supposed to trip. When the breaker trips it doesn't always trip all the way to the side, sometime it looks okay so shut the circuit breaker off and reset it and then do it again to make sure you did it right the first time. If that does not cure your problem you might have blown your thermal fuse (Item #5016) or blown the power control board (Item #5070)
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Range-Parts/Model-LRE30453ST/3204/0124111/F0903017/00005?blt=06&prst=0&shdMod=LRE30453ST
But since the display screen is also completely blank it could be one of the PCBs in the control panel.
Aug 16, 2011 | LG LRE30453ST (Electric) Stainless Steel...
The monitor keeps going blank with a message ''no signal'' or ''out of range''.
Probably you are out of the resolution range for this monitor. Try to boot you computer in safe mode (for low resolution) using F8 just before the windows start screen, step down the resolution, restart and try step by step to upgrade the screen resolution.
Stelios.
Feb 21, 2010 | Computers & Internet
Blank square on screen after installing a Linksys USB adapter
This is a problem with the wireless adapter to correct this problem you uninstall and download the latest software from linksys site and install that one to your computer...
Sep 26, 2009 | Linksys Rangeplus Wireless Pc Adapter
Screen goes blank and message comes up saying "input signal out of range"
When does the screen go blank? Also what do you have plugged into it this most likely just because your input signal may be set at to high a resolution or frequency. Once I have more information I can assist you further.
Thanks,
Lee
Aug 11, 2009 | LG Flatron L1515S 15" LCD Monitor
Getting out of range on my ViewSonic Monitor
try to check the memory. sure its on the board.
May 05, 2009 | Computers & Internet
Clock/oven/temp screen for a Jenn-Air electronic range #SVE87600
I believe Jenn Air will pay a portion or electronic parts replacement on their ranges less than 5 years old.
You might try unplugging the stove for 1 hour and this is supposed to reset the stove to factory settings
Sep 06, 2008 | Kitchen Ranges
Relisys Monitor model TL528A - Plug it in, screen is blank panel light is yellow. push ON button and I get a 5 second message stating: OUT OF RANGE HS: 53.5 KHz VS: 84.8 HZ WORK RANGE ...
It normally means that you have connected the monitor to a computer whose resolution and frequency are beyond the range that this monitor are capable of.
To fix this, you can do one of two things: reconnect the old monitor and reduce the resolution to 800 by 600, which every monitor can handle and then reconnect the new monitor and change the resolution settings again. by default, Windows will restrict you to only settings that the monitor can handle. The second option would be to start your computer in safe mode (F8, just before you get the windows screen during boot). and change you monitor settings that way, rebooting afterwards.
Jul 10, 2008 | Computers & Internet
Screen goes blank
Maybe the setting of your video display was change to higher setting, and your screen cannot handle the said setting.
When a "safe mode" message appears during opeing, select that options, then at the desktop right click your mouse, chose properties, then setting, then change the screen resolution to lower range.
Dec 05, 2007 | GPS
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
