11 blue dots print out down the left hand side of documents
I've just installed an HP Colour LaserJet CP2025 dn printer. Every time I print 11 blue dots, evenly spaced, appear down the left hand of the margin of the document. How do I stop this happening please?
    Genius:
  • 2,120 Answers
It sounds like the CYAN toner cartridge is leaking.
Posted on Jan 23, 2009
HP color laserjet cp2025 will not print. Help.
No.
Very few printers will print if they're out of toner, even if the colour toner is exhausted and the print job is only black. Replace the empty toner and if this is the only problem, the printer will continue printing.
Jan 20, 2015 | HP Laserjet Cp2025n Printer
Black dots are printing on the left hand side of the page when I print from my hp laserjet 1015. Any ideas how to fix this?
Run a "half test". Put paper in the manual feed tray. Print anything. Watch the paper, when it feeds about 1/2 way into the printer, open the cover. Pull out the toner and look down at the paper. If it has the dots, replace the toner. If it doesn't have dots, the fuser is probably bad.
Aug 31, 2011 | HP LaserJet 1018 Printer
HP colour laser jet CP2025. Prints colour on test sheet but not from pc. It was printing colour until wireless was installed - is there a connection?
Your driver is not sending color data. Either your driver is set to print in geayscale, or you are printing through a monochrome driver to the IP address of the CP 2025
Jun 30, 2011 | HP Laserjet Cp2025n Printer
Hi, I have HP LaserJet 1020 and few days ago three tiny black dots appeared on the left side of the printed pages, just by the border. The borders apper at regular intervals. I found somewhere that it...
dots printed are from the cartridge, you proved that with the change to the old one. If the fuser was faulty, it would repeat the dot 2.5 times down an 8.5 x 11 page
Replace the cartridge and please use HP , remanufactured cartridges fail prematurley and usually wind up costnig more in service and repair/exchanges.
Jan 15, 2011 | HP LaserJet 1020 Printer
My CP2025 is printing tiny colored dots on my pages...what do I need to do?
You will most likely need to change what ever toner cartridge that is the same color as the dots. So if the dots are pink change the magenta. If they are blue change the cyan. Most of the time these dots are a result of the toner cartridges drum having a pit or similar defect in it. Changing the toner cartridge will take care of this.
Good Luck and Thank You for using Fixya.
Oct 09, 2010 | HP Laserjet Cp2025n Printer
My printer is hp laserjet cp 1515n. After printing some documents it writes "printing cool down mode" and begins working very slowly. Please help me
1515n - I have the Magenta colour 'shadowing' the blue test. A mirror image of the blue text. [slightly staggered] Black is fine. Applies to all Word docs when printing in blue - can you help please?
I only use genuine cartridges.
Thanks
Jules Radstock
Jul 23, 2010 | HP LaserJet CP1518 Printer
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
4 colour dots on printout but not 150mm apart
Measure the distance between two of the same coloured dots down the page, if it is just over 150mm then it is caused by scratches on the photoconductor drum (this is the only thing that has a 15.4mm circumference). Try printing a black and white only document, only the black dots should appear. Removing the photoconductor and gently polishing the blue drum with a soft cloth can help if the scratches are not too deep, otherwise a new photoconductor is the only route.
Sep 06, 2009 | Epson Aculaser C1100 Printer
It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
Apr 14, 2009 | HP LaserJet 4600dn Color Printer
681 people viewed this question
jasbo
jasbo
