Question about Jenn-Air JMC7000 Microwave Oven
Microwave won't heat up food,
Everything works on display panel.. plate rotates , but when you turn it on you hear a roaring sound -- same type of humming  noise it normally makes when it used to work but now magnified and as i said ..it doesn't heat anything up. need help thanks.
  • jinggotan22 Jan 26, 2009
    if the magnetron coil is not working and the unit is at least 6-7 years old..what do i do? is it replaceable? and how do i confirm it is the magnetron coil? is there a way to check it. The previous answer did not seem to offer any solutions. Hope i'll get one that could take me through steps to figure out what's actually going on. thanks.
  • 916 Answers
With the symptoms youhave, I would think the problem is either a shorted high voltage rectifierdiode or a bad magnetron.
The diode is acheap fix but the mag will cost more and is more complicated to replace.
Posted on Jan 26, 2009
  • 130 Answers
That is a magnatron tube. The unit that provides the heat. most common part to replace on a micro
    Genius:
  • 1,239 Answers
Hi
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let me know if the hard reset doesn't fix it and please reply back .......
Posted on Jan 22, 2009
  • 350 Answers
If your microwave is a Jenn-Air then....
Stop turning it on and contact Jenn-Air right away!
Click on the link below for live chat, phone #s, parts & more
http://www.jennair.com/content.jsp?name=contact_us
  • Jack Iaria
    Jack Iaria Jan 31, 2009
    Has ANYONE HELPED FixYa?
  • 13,433 Answers
When themicrowave sounds okay, but there's no heat, one of the internal doorswitches, the high voltage circuitry, or the circuit board may have aproblem. To resolve this problem, you need the assistance of aqualified appliance repair technician.
You can inspect the door switches at home.
our microwave expert
MicrowaveSvc
has talked about the switches here
http://www.fixya.com/support/t127617-microwave_heat_food
    Genius:
  • 1,550 Answers
The magnetron coil is defective in your unit .
How old is your unit ?
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
Microwave stopped heating. Everything else still works - it comes on, the light comes on and the plate rotates and it dings when it done, but te food is still froozen.
Sounds like either the magnetron or its high voltage power source has failed.
It is extremely dangerous to work on the magnetron side of the power system. It CAN and DOES KILL!
Dec 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave will not heat food everything else seems to work, timer, rotating plate everything works but heating food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
=0=0=0=0=0=0=0=0=0
Sep 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I hv a 24ltr Sharp Carasoul Microwave. Few days back, its plate stopped working, but its heating the food fine. Why has the plate stopped rotating? Will the food be evenly heated even though the plate...
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You order Sharp parts Encompass here or call them toll-free at 866-779-5835.
> Will the food be evenly heated even though the plate is not rotating?
No.
Sep 07, 2010 | Sharp R-1480 Microwave Oven
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Jun 01, 2010 | Frigidaire FMV156DC Microwave Oven
Maytag mmv1153BAB built in plate not turning
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
To replace either is a pretty simple job.
You need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Sep 28, 2008 | Maytag MMV1153A Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
26 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
