My HP Notebook starts up ok and then the windows page loads and the moving dots moving back and forwards in the bar and then the screen goes blank and it shuts down and starts back up again going round in a circle.
Systems do this if the os hasnt been registered within the time limit or you could have missing sys files either way you'll have to re-install windows either repair existing os or fresh install..I suggest fresh install....you could try booting to safe mode then restart using option start with last known config that worked..you could even try startup from usb to get to dos prompt(virtual dos)
and type in win and enter or type first "chkdsk"which if successful will check and repair any errors;but if they all fail and quite possibly they will you'll need to reinstall anyway.
Try starting windows in safe mode and go to an earlier system restore point if that wont work try installing windows again if windows wont respond to this it will be a hard drive issue it will need replacing
