Question about Stihl Chain Saw Handle Models 044 046 Ms440 Ms460
Where is the bar oil adjustment screw for a stihl ms460
Need to know where bar oil adjustment screw is located
  • Stihl Master
  • 1,807 Answers
Turn the saw upside down, there is a flat head screw adjuster that is accessible from underneath (the bar side of the saw) it will have a + and - sign near it.
Posted on Mar 05, 2016
I have a Stihl MS 290, runs great, but the chain keeps tightening it's self on it's own
That's an unusual problem, usually the opposite happens. After making sure the chain brake is off, loosen the two nuts that hold the bar. Be sure to hold the bar up when adjusting the tensioner screw and adjust until the chain is just snug, but not too tight. While still holding the bar up, tighten the two nuts firmly. Check to see that the chain can move freely by hand. Then start the saw and run the chain at speed with something in front of the nose to check for adequate lubrication. You should note a slight fine spray of oil on the object in front of the nose of the bar. Inadequate lubrication, a chain that is binding on the bar, or an overly tight chain can cause the bar to heat up and expand, further tightening the chain. A properly adjusted Stihl saw will use almost all of the chain oil in the reservoir for every tank of gas. Too much oil is better than too little. The oil feed may have to be adjusted for operating in temperature extremes. If operating in very hot conditions, be sure that the saw has not run out of chain oil. The oil feeds faster when hot.
Sep 19, 2014 | Stihl MS 290 Chain Saw include 20" 50cm...
No oil to chain stihl ms250
Oil pumper oil gear, needs to be adjusted or replaced. Check out a video how to replace.
Nov 29, 2013 | Stihl 021 023 025 Ms210 Ms230 Ms250...
How do you start a STIHL MS460 chainsaw
I am a Stihl mechanic. The proper starting procedure is to set the switch to full choke. Pull the starter rope no more than three times.Now raise the switch up one notch and pull it till it starts. Stihl products will flood if pulled more than three times with the choke on. Thanks, George
May 08, 2012 | Stihl Chain Saw Handle Models 044 046...
Having trouble finding how to start the ms460
Hold the trigger and move the lever on the left all the way down -you know what? if you can't figure out how to start a Pro saw like a 460, you shouldn't be using it at all.
Cannot find oil regulator on stihl 024
There is no oil "regulator" only an oiler with a screw that adjusts the flow, that is found below the saw, and is fit for a slotted screwdriver.
Jan 11, 2012 | Stihl MS 290 Chain Saw include 20" 50cm...
Dont no how to ajust the ioler for the bar oil uses a tank of oil to a half tank of fule burned
what brand saw? Stihl saws are made to run Stihl oil. If you are runnin other oil, the viscosity wont be the same as the pump is designed for, and the oiler may pump more then it should. The oil adjustment screw should be a single flat head set screw on the underside of your saw near the sprocket. Alot of saws are not equipped with an adjustable oiler. Professional saws and larger displacement saws will have the feature.
Sep 15, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Where is the oil adjustment screw on the stihl 028 AV
Most Stihl saw have the adjustment screw on the bottom of the saw. The ones I've seen have an E mark which the factory setting. Turn the screw clockwise to increase the oil and counterclockwise to decrease it.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 16, 2011 | Garden
Too much oil is being delivered on the chain, how do I adjust the oiler on my Stihl 038av super?
This is Stihl's manual showing the proper adjustment for the oiler. Flip the saw on its side, chain and bar side up, and look for a flat head screw.
Clockwise rotation on any saw is more oil, and counterclockwise will be less oil.
Nov 25, 2010 | Garden
I have a ms 290 farm boss with an 18" want to
Yes! So here are some links:
STIHL Ematic guide bars are engineered and manufactured to STIHL's strict quality control standards and are produced in STlHL's own factories. STIHL offers a full line of guide bars for all types of use from 10" for specialized wood carving applications with small saws through 59" for extreme felling operations. Explore our products to find the STIHL guide bar that's right for you. Locate your local STIHL dealer.
arrow_orange.gif STIHL ROLLOMATIC® ES Super arrow_orange.gif STIHL ROLLOMATIC® E Light
arrow_orange.gif STIHL ROLLOMATIC® E Standard arrow_orange.gif STIHL ROLLOMATIC® Mini
arrow_orange.gif STIHL DUROMATIC® E arrow_orange.gif Carving Guide Bar
Thumbs back!
Nov 07, 2010 | Stihl MS 290 Chain Saw include 20" 50cm...
I have a stihl chainsaw model #311y and I need to tighten the chain .Can you help me?
loosen bar nuts, with gloved hand push up on bar, and turn adjuster screw clockwise. on stihls it's either beside bar facing forward or between bar nuts.
Feb 05, 2010 | Standard Oregon Chainsaw Chain For Stihl...
Stihl Chain Saw Handle  Models 044 046 Ms440 Ms460 Logo
552 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
