Question about ASUS M2N-MX Motherboard
What is the best way to get my data out of a dead hdd.
I have an IBM Deskstar and is making a serious noince whick my computer cannot recognized it again. I have slaved it, used USB cable and connect it to the computer but still no way out
I want this dater out pls.
Thanks
  • 70 Answers
One trick I have learned as a technician, when the problem is data-read errors off the plattersthemselves, is to freeze the hard drive overnight. It makes the data more 'readable,' but for a
one-shot deal. If this data is critical, and you have a replacement hard drive (which, if it's a drive failure, you probably do), then you can hook up your frozen hard drive and immediately fetch the data off before it warms up.
http://itlesson4u.blogspot.com
or if you have deal with dead head
you must get same type and model hdd
then replace the platter with your original hdd platter
you need kindda special screwdriver and the patter must not touched and dusty
then connect the replaced platter hdd to your computer
please rate!
Posted on Jan 22, 2009
How repeiar my bad sektor hard
You can't really repair it. Replace it under warranty is the best option. If you need data recovery I suggest http://FreeDataRecovery.us
Sep 22, 2012 | IBM HITACHI Deskstar P7K500...
Dead processor. good hard drive
get external hard drive shell, place the hard drive in it, the connect via firewire or usb all your info should be intact except if its a crash
Mar 23, 2010 | IBM ThinkCentre A50 PC Desktop
How do i install a used hard drive into an eMachines T2341? The hard drive still has information on it. do i set it as master, slave, or cable select? hard drive is an IBM 10.1 gb
There are two possible solutions depending on how your desktop is setup.
#1 install the 2nd hard drive and put jumper to CABLE SELECT. When you start the computer it should now appear in the bios as a SLAVE or 2nd hard drive. If not go to #2 below
#2 Turn system off again and change jumper on 2nd hard drive to SLAVE.
Now when your computer restarts it will appear in your bios correctly as the 2nd drive/SLAVE.
Do not make it "MASTER" or you will be trying to boot up to this drive and it may not work as you planned.
FYI: "Cable Select" means the hard drive determines which one is Master and which one is Slave by where it is on the data cable.
Good Luck
Dec 30, 2009 | Computers & Internet
Where can I find a XP driver for my IBM Deskstar 34GXP 20.5 GB ATA-100 Hard Drive (I have only the W98 version).
http://www.hitachigst.com/hdd/support/download.htm
quote " IBM today announced it has completed anagreement to combine its hard disk drive operations with Hitachi's,forming a new company called Hitachi Global Storage Technologies. " unquote. there is a link to the support site...you might have already been there..i don't know...here is another site but i think you will have to register...it has helped me alot.
http://www.driverguide.com/.....
you could also google xp driver cd . i have one and it also helps.
Aug 14, 2009 | IBM Deskstar 34GXP 20.5 GB ATA-100 Hard...
I have just removed a IBM Deskstar (DTLA-307015) from my desktop and installed into a external enclosure just turned it on and it worked without installing any drivers. I want to know is this set up right?...
since you said that the HDD works you have nothing nto worry, that means you have installed it correctly. as for clearing it up suggest you do a complete format. when you plug in the USB the pc will assign a drive name to it. note it down. the right click my computer/manage/disk managment(from the left panel) right click on the drive you noted down & format.
Mar 18, 2009 | IBM Deskstar 75GXP (DTLA-307015) 15.4 GB...
Cannot see drive letter for deskstar 7k250 in usb enclosure winxp
Add a letter for this HDD in "control panel\performance and maintenance\administrator tools\computer manager=ment\disk management"
Feb 16, 2009 | Hitachi Deskstar® T7K250 250 GB Hard Drive
Netfinity 550 "drive not found"
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Dec 02, 2008 | IBM Netfinity 5500 M20 4RY (86624RY)...
Trying to get data off an IDE drive from a dead system
this MS link will help you configure it so you can read it
http://support.microsoft.com/kb/309000
Oct 27, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
IBM Deskstar Model IC35L040AVVN0-0
Well, I guess your running windows XP ? If you open the disk manager, does it show up there ? When you reboot, does the Bios discover the drive ?
May 29, 2007 | IBM Deskstar 22GXP (DJNA-372200) Hard...
ASUS M2N-MX Motherboard Logo
24 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
