Televison & Video Logo
A
Anonymous Posted on Jan 11, 2013
Manual for magic remote an-mr3005 - Televison & Video
I am trying to set up my LG Magic Remote to work with a Openbox V8S, but openbox is not listed? Does anyone know how to do it?
Magic Remote Control - LG Smart TV: Online User Guide
eguide.lgappstv.com/manual/gb/12018.html
Your LG Smart TV includes a Magic Remote Control that acts as both a cursor ... Toconfigure the speed, shape, and size of the Magic Remote Control pointer, ...Missing: openbox ‎v8s
[PDF]Magic Remote - LG.com
www.lg.com/us/.../AN-MR500%20owner%20manual.pdf
LG Electronicswww.lg.com. Please read this manual carefully before using your remote and ... Magic Remote and Alkaline Batteries (AA) ... Press the up, down, left or right button to scroll.... The Magic Remote may not work properly if a wireless router (AP) is.
LG ANMR500 Magic Remote Control LG Universal ... - eBaywww.ebay.co.uk > ... > Remote ControlseBayLG ANMR500 Magic Remote Control LG Universal Remote - Richer Sounds in ...We've tried to explain some of the more exotic functions and facilities you might ... us with are incorrect or if any order is held up as a result of incorrect details. ... Returns • Goods, other than faulty goods, may be returned within 7 working days ...New Genuine Remote Control Magic Smart TV's LG AN ...www.ebay.co.uk > ... > Remote ControlseBay
I bought an lg an-mr500 magic remote to accompany my lg 42lb580v-zm but cannot register the magic remote.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
LG MAGIC REMOTE MANUAL
tell me the model of the magic remote and I'll be able to provide you with one asap
I cant connect my one for all remote to my toshiba tv
One For All has an extensive online website with manuals for all their remotes. Without you remote model number it is hard to provide a more definite answer.
One for all urc2060 need codes for sharp tv
Enter your model of the tv and search for the tv manual.... http://www.sharpusa.com/CustomerSupport.aspx
OR
The following will take you to the instructional pages for the remote. Start with one of the two links below.
Your remote will set up in one of the following ways:
Set Up #1
  1. Press the button for the device you want to program, then release.
  2. Press and hold the Magic button until the red LED gives a delayed blink.
  3. Continue holding the Magic button while you enter your 3 digit code.
  4. You should receive 2 quick flashes after entering your code.
Look on the back of your remote for the instructions. If they match these, press here for more instructions for his remote.
Set Up #2
  1. Press the button for the device you want to program, the release.
  2. Press and hold the Magic button. You will see two blinks on the remote. Release.
  3. Press the three digit code for the device you want to program.
  4. You will see two blinks. Your remote is now programmed for that device.
Look on the back of your remote for the instructions. If they match these, press here for more instructions on this remote.
Can't find the Magic button on my URC-2410
there is a star button on the remote or maybe a button with power. that is the magic key!
TV will not turn off with remote or manually
That means that you either need to buy a replacement remote (or use an universal remote) , or you need to replace the TV IR sensor, that is a small board located inside tv.
TV will not turn off with remote or manual have to unplugged
I suspect the unit might need service. If it were only the remote, new batteries would, of course, be in order. But that part about the manual power button being ineffective suggests something else is affecting the set. Sorry.
2answers
TV automatically turns magic focus mode on when the power button is pressed on the remote and even manually.
I have this problem starting today. Unfortunately, others who have fixed it have done the following.
* Unplug TV for hours and it worked
* Buying manual switch to the outlet or surge protector and switch power off that way.
It appears that I'm in no mood to spend hundreds to get this fixed for hundreds of dollars and just going the Radio Shack route of buying a switch which would probably be more of savings. But needless to say, I hope that is the only problem I have.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
