Question about Karcher K2.26 Electric Power Washer
LOST KARCHER INSTRUCTION BOOK, ARE INSTRUCTIONS ON LINE
I need to read Karcher instuctions to see if I have connected pipes correctly. I have not used the Karcher for several years and have forgotten how to connect correctly.
The water pressure when switched on is the same as that from the water tap
  • 12 Answers
Here is the offical link to manuals and warranty cards for the residential models of Karcher Pressure Washers
http://www.karcherresidential.com/us/Service/usermanuals.htm
Posted on Mar 04, 2012
  • 2,176 Answers
Looking at the manual for the Karcher you listed the high pressure hose is on the front side, if that is what you asking, if not I would suggest going to Karcher.com and it will walk you thru on how to download another manual, BUT this manual is 48 pages long. Let me know if I can do more.
Posted on Jan 23, 2009
How do I fix a problem with my Karcher K4 pressure washer.
Sharon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Grumpy gits and useful tips
How to FIX Karcher pressure washer
Karcher North America Home Garden Online Help
Aug 09, 2016 | Karcher K 5.85 M Electric Pressure Washer
How to connect the telescopic jet pipe to my Karcher K7?
Karcher utilizes a europeon fitting known as 22 mm female out of pump need to know type of fitting on wand they have adapters .telescopic wands may be standard either 1/4" quick disconnect or national male pipe thread
Aug 20, 2014 | Karcher Garden
Water coming out of detergent pipe from top for karcher 3030 B jet wash.When i start using the jet wash there is not enough pressure and water starts coming out of detergent pipe.How can i stop water...
remove deterfent pipe,unscrew detergentnozzle carefully, inside is spring and ball bearing, clean and re-fit, replace if missing. spring on upstream (soap) side
Apr 03, 2014 | Karcher Garden
Water coming out of detergent pipe from top for karcher 3030 b jet wash
DISCONNECT HYDRO OR WITH ENGINE NOT RUNNING DISCONNECT SPARK PLUG THEN RE-LEAVE WATER PRESSURE BEFORE SERVICING the detergent pipe plugs into a pipe on the pump, under which is a spring and ball bearing (stuck open, debris) WEAR YOUR SAFETY GLASSES
Apr 01, 2014 | Karcher Garden
Karcher vaporapid 1105 manual
there should be a labeled fill line on the clean water resavore
Mar 26, 2014 | Karcher Vacuums
I would like the instruction book for the Karcher k2-59 pressure washer
The manual is available on the Karcher website here:
http://www.karcher.co.uk/uk/Products/Home__Garden/Pressure_washers/Entry_class/16724110.htm
Click on product manuals and then pick the fourth file in the list.
Mar 21, 2011 | Microwave Ovens
I need an instruction book for my Karcher pressure washer model no. K2.87m
The Karcher manual is available at this address.
Hope it helps!
http://www.karcheroutlet.co.uk/Manuals/Pressure%20Washers/K%202.87%205960-759.pdf
Feb 21, 2011 | Electric Eyeware Karcher Electric Pressure...
Karcher k 3.99 does not pause correct
Is there a water leak from the bottom ?
Is so, then there maybe a small crack in the seam of the plastic manifold pump housing or one of the connecting fittings. A New Manifold Complete about $61.00. You may purchase direct from Karcher, and replace if you are mechanically inclined.
If under 1 year old, and you can find a receipt, Karcher will replace the whole Pressure washer under warranty.
May 09, 2010 | Karcher K 5.85 M Electric Pressure Washer
No manual on how to use Karcher K5.86
Go to following website address
www.karcherresidential.com/support/downloads/pdfs/usermanuals/5962-1030.pdf
This is for K5.85 but maybe it is same.
Mar 15, 2009 | Karcher Garden
Water gushes out of the inside of my Karcher jet washer.
you can sometimes seal the water leak from the inside as I think your water inlet case has split
Jan 07, 2009 | Karcher Quick Connect Nozzle Set
Karcher K2.26 Electric Power Washer Logo
4,460 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
