Canon scanner DR -2580C not working at all ,green lightis flishig
I bought this scanner Canon DR -2580C from E Buy , good price but it is not working.
I installed all the drivers and computer recognized the scaner and seemed fine at first apearance than when I have to scan apears two error
Scaner Cover is open -4429
si Driver in use by another program -4539
Checked the cover is closed , properly closed maybe could be soemthing else, please give me an advice
Thanks You
Daniel M
  • shoe20 Apr 09, 2009
    same exact problem
  • 319 Answers
SOURCE: Scaner Driver
http://www.scanner-drivers.com/drivers/77/77791.htm
Posted on Dec 31, 2007
SOURCE: from where i can get soft ware of scaner.
I am looking for software for scaner 3300U
Posted on Jun 25, 2008
SOURCE: CanoScan Lide 25 scanner
driver scan saya hilang gimana cara mendownload drivernya
Posted on Oct 16, 2008
SOURCE: Driver For vin vista acer for Flatbed scaner 13
This solution works with the following Acer models on Vista 64.
FlatbedScaner5 ="Acer scanner 310U/620U" FlatbedScaner13="Acer 320U/340U/620U+/640U" FlatbedScaner16="Acer scanner 620UT+/640UT" FlatbedScaner19="Acer scanner 1240UT/5100U" FlatbedScaner20="Acer scanner 640BT/640BU" FlatbedScaner21="Acer scanner 4300U/3300U" FlatbedScaner23="Acer scanner 4300U/3300U"
The driver package includes the following files with file sizes ahead.
108,032 acerscad.dll 3,269 acerscan.inf 24,192 ksthunk.sys 451 Model.ini 17,683 sti.inf 30,663 u126v041.bin 30,598 u176v040.bin 32,301 u190v041.bin 31,664 u192v073.bin 30,221 u222V065.bin 27,984 u34v110.bin 31,364 u64v119.bin 31,048 u96v121.bin 27,648 usbscan.sys
All these files are derived from those on Windows XP64. Maybe it works on Vista 32.
Posted on Dec 16, 2008
mohanchennai
  • 490 Answers
SOURCE: error message -4431
If the scanners keeps blinking while powering on, it is because it has not been intialised. Check for loose shreds of paper in the paper path. Unless the scanner intialises, it cannot scan. If simpel 'countonly' option works, then the scanner is okay.
S. Mohan, Chennai, India
Posted on Mar 18, 2009
Canon DR-2580C scanner only scanning half the page. What could be the problem?
Select Auto for page size. The scanning software displays scanned image in many options, including 'fit'. Choose 'fit' so that you see complete image.
S. Mohan
Dec 29, 2011 | Canon DR-2580C Path-Through Scanner
Black at the bottom of scanned pages
There should not be a thick black line at the bottom, but could be from several things, light coming in from somewhere is my first guess, toner is almost out or the ribbon is getting stuck on the inside at that point. You may have to call Cannon and ask them.
Aug 21, 2009 | Canon DR-2580C Path-Through Scanner
Dr-2580C Grabs more than one page at a time!! Losing Info!
If the rollers are old, you need to change it, else clean with a damp cloth. Dont use solvents. Ensure the papers are not sticky, loosen them if required.
S. Mohan
Mar 31, 2009 | Canon DR-2580C Path-Through Scanner
I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
Mar 19, 2009 | Canon DR-5010C Scanner
Canon DR 2580C Scanning issue
In Captureperfect, select page size as 'Scanners Maximum'. Select automatic paper size, check the output now. If you select bigger paper size and smaller paper, you will see lack output, outside the paper area.
Nov 26, 2008 | Canon DR-2580C Path-Through Scanner
Canon Dr-2580C
Try and scan a white paper. If the output is black, then may be the LEDs are not glowing, likely the wire is loose. Actually it is not easily reacheable! Try duplex scanning to check if both scan modules are fine.
S. Mohan
Oct 14, 2008 | Canon DR-2580C Path-Through Scanner
Error message -4431
Sep 04, 2008 | Canon DR-2580C Path-Through Scanner
Canon DR-2580C Scanner
You must have 'checked' the multipage option in the scanning software. Try scanning first page only and store as say temp1 and later all pages as temp2. If the file size is different you can deduce that the scanner has scanned all pages! To view multipage files, you need a proper software.
S. Mohan, Chennai
Nov 29, 2007 | Canon DR-2580C Path-Through Scanner
Error Message-- Error in shading position (-4431)
The issue at hand here is a sensor error. Cut the power to the machine for at least five seconds. Then reboot the scanner and the sensors should reboot. This solved the problem for us. Good luck to you.
Nov 21, 2006 | Canon DR-2580C Path-Through Scanner
789 people viewed this question
jasbo
jasbo
