Question about Hotpoint TDC32 Electric Dryer
Why does it take hours for the empty water light 2 go off
When my water tray needs emptying the light will come on but when i empty it the light takes hours to go off before i can use my condensr dryer model number tdc62s any solutions would be appreciated
Take that water pump off and clean it.this worked for me
Posted on Mar 03, 2009
Empty water light does not come on,so water overflows from drawer...what can i do?
empty it more often..............check it every hour or so.........dont rely on the light
cheers
Feb 19, 2015 | Hotpoint tcm570p Aquarius Condensor Dryer...
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
LIGHT FLASHING EMPTY WATER,CUTTING OFF WHEN WATER EMPTIED
Try cleaning the water sensor, it may need to be replaced though.
Dec 22, 2013 | Dryers
I have a Siemens e44-10 dryer. It works for few mins and that stops. The light looks like. Up of water flashes. I cleaned all filters, and the water tank is empty. Can u help me?
I had the same problem above. I tok the side panel off and disconected the float and cleaned it. I noticed alot of water mixed with dust. I used a dry cloth to get the water away and made sure the reservour was clean. I assembled everything and it is all working. Tips, make sure the condense tray is emptied after each Washington aswell as the dust filter. Clean out bottom filter once a month. This saved me having to buy a new machine and tok just half an hour. Phew, money in the pocket!
Aug 03, 2012 | Dryers
Empty water light stays on and doesnt get hot
allways with this type of unit it is best to always empty the container after every dry,this is because when the water rises in the pump chamber it operates a switch which shuts of the heater and puts on the light. and they stick quite a lot,disconnect from power and rock the appliance from front to back quite hard and this should rectify the problem
Jun 27, 2009 | Dryers
Water light on saying full but water container is empty
The problem is with the lower water tank float switch, it is stuck. Take off the right hand side panel (as you are facing the machine) at the bottom you will see a spring mechanism for the belt tension. Beside this there are 2 electrical connectors. Take them off and spray with wd40 or similar. Whilst off give the plastic box they fit 2 a light tap with a hammer to free the float switch. Reconnect and try. If this fails you can over-ride by leaving the left hand of the two plugs off. This will get your machine working but you will not have an indication as to when the water container needs emptying so you will need to remember.
Sep 17, 2008 | Dryers
Seimans dryer txl733...incessant buzzing warning light to empty water resevoir even after emptying?
hiya
i take it this is a condensor dryer, the most likely cause of this will be the float in the recirculation pump (takes he water from the condensor unit to the bottle) sometimes these just stick and once freed they work ok, other times they will need replaced.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 03, 2008 | Siemens Dryers
Hotpoint aquarius CTD00 dryer won't heat
I have just had a similar problem and fixed it today.
The "Empty Water" light was staying on and no heat was given out to dry the load.
I found it to be the float switch in the condenser unit at the back left. It had stuck with fluff and debris. I cleaned out the condenser reservoir and the polystrene float and now all is well.
To get to this unit you must first,
Take of the top and the left hand side panel.
Locate the 2 locking tabs that hold the top half of the condenser onto the back panel and release this part.
Remove this by releasing 2 further tabs that hold it to it's bottom half,
and you will see the float switch assembly on the left hand side.
Clean out the condenser reservoir of any water and aslo clean the polystyrene float, it needs to be free to slide up and down between the plastic guides.
Hope this helps.
JohnM
Jun 28, 2008 | Hotpoint NWXR473EV Dryer
Water empty light wont go out
the black wire that was moving water from down condenser to up - water container - remove it. Use cotton swabs to "clean" the holes, do a run of the dryer without that black wire connected ( carefull, cause some wated might spill at this point), reattach black wire, and enjoy :)
It worked for me anyway. ( fingers crossed, its been on for 20 mins and still no red lights flashing)
Dec 30, 2007 | Hotpoint TDC32 Electric Dryer
Bosch classixx condenser drier
Nov 30, 2007 | Bosch Axxis WTA4400 Dryers
Hotpoint TDC32 Electric Dryer Logo
238 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
