Question about Xerox XC356 Copier
Xerox xc356 copier
The copier was low on toner and always was jamming sheets when copying. i kept shaking the toner cart up to use the last of it and finally replaced it with a new cartridge. the copier now wont come on at all. i dont know if taking the cartridge in & out and pushing it in (tight) too many times did something? i cant get it to power up. can you help?
  • 38 Answers
TRY TO CLEAN THE RUBBER ON FEEDING PAPER WITH A DRY CLEAN CLOTH AND DROP A SOME ALCOHOL IN CLOTH AND CHECK THE PAPER PATH IF HAVE SOME A LITTLE PAPER ON PATH PAPER... ABOUT CATRIDGE...TRY TO REPLACE A NEW CATRIDGE.. DO THIS NECESSARY UR COPIER IS ON. panlaqui08@yahoo.com.ph
Posted on Jul 06, 2007
I cannot get the drum cartridge out of the XC356 copier by Xerox. I have lifted the green tab, however it is still locked or hard to come out and I am afraid I will break same. Do I need to do something...
You can always find a soution to your Xerox problem at www.xerox.com/support Here is a link to this solution:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=22,E=0000000002703238142,K=7389,Sxi=4,Solution=obj(18692)
  1. Turn the copier off.
  2. Remove the Toner Cartridge:NOTE: If you are not sure how to remove the Toner Cartridge, refer to Related Links at the bottom of this page.
  3. Remove the Input Tray on the right side of the copier, if applicable.
  4. Slide the Platen to the right by pushing in on the grey square Release Button on the back of the copier, then sliding the Platen.
  5. Fold up the Exit Tray on the left side of the copier, if applicable.
  6. Stand the copier upright on its left side.
  7. Remove the Bottom Access Door (see Related Links).
  8. CAUTION: Be careful not to touch the red surface of the Drum.
  9. Locate the green Drum Cartridge Release Lever at the bottom of the Drum Cartridge.
  10. Lift up on the Drum Cartridge Release Lever.
  11. Pull up on the bottom of the Drum Cartridge. The Drum Cartridge will pivot upwards.
  12. Pull back on the Drum Cartridge to remove it from the copier.
Jan 26, 2011 | Xerox XC356 Copier
How to replace toner cartidge of the Xerox Copier 5225 machine?
The toner cartridge is located in the upper centre of the front of the copier. Open the front door, slide out the cartridge until you see the top handle, whilst pulling out hold the top handle to avoid the cartridge tilting and leaking any excess toner inside the machine.
Before inserting your new cartridge, gently shake it from side to side to ensure even distribution of the toner. Slide the new cartridge in until you here a click, then close the front door. Your copier may go into a calibration routine for a minute or so if the developer has been starved of toner. If it hasn't, it will be ready to copy straight away.
For a quick user guide on the copier go to http://download.support.xerox.com/pub/docs/WC5225_WC5230/userdocs/any-os/en/EN_Online5230_5225_5222_QUG.pdf
Hope this helps.
Jan 21, 2011 | Xerox Workcentre 5225 / Copier, With...
My xc356 copier prints dark lines on the copy, toner has been replaced
If it is just with copies, then you have either dirty optics or dirty glass which you must clean. However, most likely the problem is with the imaging drum. If you are able to remove the drum, I suggest cleaning it with soft cloth or rag, then reinsert and see if the problem persists. If the issue does not go away, then I would suggest having a technician coming out and seeing if you need the drum replaced.
-David.
Nov 02, 2010 | Xerox XC356 Copier
Print black pages and jam pages
please check exposure lamp. Is it go on when press copy button?
Sep 15, 2010 | Xerox XC356 Copier
J2, toner low, but powder in toner cartg. Remove
All this means is that your toner is getting low and advising you before it is out completly the it needs replacing.
Dec 15, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Paper won't go through xerox
Under rubber roller of the presenting the paper is located brake platform. Check as she works. This often can be that paper pulls not exactly. Follows to restore the brake platform. Good luck.
Oct 07, 2009 | Xerox XC356 Copier
Xerox 3001 Copier. I installed new toner and the
Paper must cover the center to hit the sensor. If paper still goes through without stopping, the paper drive clutch is faulty.
Aug 25, 2009 | Xerox 3001 Copier
Noises when printing copies
Take the new cart. out and reinstall the old cart. Does the noise disappear? I would tap and shake the toner cart. BUT BE CAREFULL, the cart is ready to spill toner. On the box and in the instructions it tells you, or should, that you must shake and tap the outside of the cart. This is due to settling and the toner maybe packed. By tapping and shaking it will feel the toner. If the toner is packed it will put undue pressure on the augers inside the toner cart. and cause a grinding noise. If after tapping and shaking, reinstall the new cart. and check. If everything is ok -- great. If the noise remains contact the company your purchased the cart. from and ask for a replacement. These cart. are mass produced and mostly reused ( refurbed). Parts wear now and they do not replace the inside parts, they just repack with toner and seal.
Dec 25, 2008 | Sharp AL 1631 Copier
Xerox Copier XC356 gives only all black copies.
WITH THIS PRINTER ITS CHEAPER TO REPLACE THAN REPAIR SOUNDS LIKE THE LED OR ILLUMINATIN LAMP IS BLOWN
Jan 23, 2008 | Xerox XC356 Copier
Brand New in sealed box , but not powering up
well, when the copier is new, it is best you take it back to the dealer and get other . You should have a warranty on this product.
May 21, 2007 | Xerox XC356 Copier
Xerox XC356 Copier Logo
128 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
quennie732
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
