Question about Ricoh Aficio 1013F Copier
Have a olivetti 4200 MF it has a error C6000 i replaced te drum and dev and fuser units and it still does not reset
5 Suggested Answers
SOURCE: Clear Service Code Error Message
you have to:
press the arrows "up" and "down" at the same time for five seconds
press the OK button
a new menu appears
select option 2: ENGINE
with the arrows navigate and select option number: 5 (MODE)
now press the right arrow until you see "810. SC RESET".
press ok
and later press "execute" (you will see it in the screen of the printer)
press "ESC" until you exit all menus
power off the printer for 30 seconds
and.... VOILá........
thats all
Posted on Jun 18, 2009
  • 15 Answers
SOURCE: Replace fusing unit error
Can you put the old fuser back, just to see if the message clears.
Posted on Apr 16, 2010
  • 903 Answers
SOURCE: how do i seperate the drum unit from the dev unit
For the 4510, the two units are provided together as one supply item and are not meant to be separated. However, if you do need to separate them, there should be two vertical screws (one in the front and one in the back) and a couple of screws on the metal plate on the backside of the two units.
Be careful when separating the two units. There is toner that can easily spill out of the PCU if it is flipped over.
Posted on May 29, 2010
  • 87 Answers
SOURCE: my ricoh ap3800c error code stated - replace fuser unit (type c) I indeed done this, and replaced it with a 2nd hand but tested working ok on another machin. The replace fuser unit(type c) error is st
You can reset the fuser using the Service Programme Mode - easier than messing with springs! You can find all the details here.
Posted on Apr 23, 2012
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
It is fuser error try resetting it by running mode 163, otherwise replace the fuser unit.
Feb 26, 2016 | Copystar Kyocera Taskalfa 181 Copier
How to reset c6000 error on Kyocera M2535dn?
try replacing the fuser it says broken fuser heat wire
Jul 23, 2014 | Kyocera Office Equipment & Supplies
ERROR CODE C6000 ON OLIVETTI D-COPIER 200MF
C6000 is usually cause by fluctuation of current(power supply).
STEP 1:
Open top cover then turn ON the machine,press System Menu then scroll down to Service Setting,then HOLD BOTH the "Start key" and "#" and press "OK".
Scroll down to Maintenance Mode then press "OK".
press 163 on the keypad
scroll down to "Execute"
press "OK"
Turn Off/On...
If C6000 appears again..,
STEP 2:
U have to reset the fuser thermostat manually.
FUSER REMOVAL:Remove rear cover,top cover,left and right cover.
Remove two screws. Unplug two connectors. Pull out Fuser unit.
Thermostat removal:
remove two screws,separate the upper part from the lower part,,
remove separation claws (3pcs each 1 held w/ screws at the rear)
remove the heater lamp,and upper fuser roller...
remove two screws that held the thermostat (circular shape)
(reset manually)
If you touch the top of the thermostat you will notice that it is in concave form...,you have to drop it hard on the flat surface in order to bring back it\'s original form which is CONVEX.
DO THE REVERSE ORDER TO ASSEMBLE.
THEN,Repeat procedure in STEP 1.
Mar 03, 2014 | Kyocera Copystar CS-1620 Black and White...
Caller service C6000 in kyocera km-2035
Error C6000 related to fuser unit, you can try to reset to see if it works, other wise you need to replace fuser unit.
try to reset following these steps:
press on the panel the key 1078 1078, this will take you to maintenance mode.
now hite the key 163 And then hit the Start key.
select Execute and press Start key again.
Turn the machine off and on.
Good luck
Dec 03, 2013 | Copystar CS-1815 Printer
Kyocera c6000 error
Fuser error try to reset it otherwise if it didnot work, change fuser unit
Nov 26, 2013 | Copystar Kyocera Taskalfa 181 Copier
C6000 error
6000 error . Broken fuser heater lamp wire The fuser temperature does not rise after the fuser heater lamp has been turned on You need to reset it in engineers service mode setting 163 ,if problem still persists after resetting a new Fuser unit will be required
Nov 12, 2013 | Kyocera TASKalfa 180 Copier
Kyocera 2050 errore code c6000 problam
Error C6000 is a fuser error.
Solution 1:
  • Turn it off
  • Wait 5 minutes
  • Turn it on and the code will be clear.
Solution 2:reset the fuser
  • First open top cover then turn on power.
  • press system menu/counter
  • arrow down to service
  • press and hold start, # then enter keys
  • arrow down to maintenance
  • press enter
  • arrow down to Sim 163
  • press enter
  • select execute
  • press enter
  • turn off power then back on
Solution 3:
  • You need to replace the fuser
Sep 25, 2013 | Kyocera Office Equipment & Supplies
Estudio350 with error c010, checked the fuser, drum unit , dev unit, all are turning freely, error comes on as soon as fuser comes to full temp
Hi
Error C010 indicates main motor fault. Please check the main motor. If main motor not running under output test, then you'll need to replace it. If motor working, u might need change the LGC board. Take the drum unit out and check inside for any irregularties in drive system belts.
Hope this helps...
Daniel
Sep 30, 2010 | Toshiba E-Studio 3511 Color Copier
C6000 error code
Hi
Error C6000 is displayed when your machine fails to reach the correct temparature at a specific time.
This is a Fuser Unit Problem, try to reset it by--
press enter
press enter
select execute
press enter
If the reset doesn't work then get your unit checked for fuser unit and fuser unit heat issues.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 09, 2009 | Kyocera Copystar CS-1820 Black and White...
Have error: C6000 on Kyocera KM-3050
Have Kyocera FS-1118MFPF that is coming up with Error C6000. Can we fix this ourselves
Aug 02, 2008 | Office Equipment & Supplies
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
